Re: Question on Comp 828-16 roller lifters [Re: madscientist] #2355558
08/17/17 05:19 PM
08/17/17 05:19 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Originally Posted By madscientist
Originally Posted By pittsburghracer
He's using Brad Penn 15-40 on this one to start out on. Like I said above after seeing how much oil comes out the lifters I will never build another one without being tubed. I think the last one I tubed I used 1/2 inch house copper tubing but there's probably something better out there to use. I'm 15 minutes from starting my duster then I can jump back on his if all goes well
I get the tubing from MSC in 6 foot sticks. I also bought the reamer from MSC and I make it so you can almost push the tube in by hand, once it's peened it can't move or come out.
Thanks. I will check that out. Do you happen to know the tubing size and part number for the reamer.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Question on Comp 828-16 roller lifters [Re: Bad340fish] #2355905
08/18/17 06:31 AM
08/18/17 06:31 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Originally Posted By Bad340fish
Originally Posted By Scamp408
828 no tubes with 40psi idle 70 through traps and 100 cold at 2500
What is your lift spec?
640/650 range and I use 10/30 race oil
Re: Question on Comp 828-16 roller lifters [Re: pittsburghracer] #2355997
08/18/17 12:39 PM
08/18/17 12:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice you must of had a block with some well placed oil galleys. That is the same lift I ran with the 828-16s and it would leak enough oil past to only run 20-30 psi on the drill.
68 Barracuda Formula S 340
Re: Question on Comp 828-16 roller lifters [Re: Bad340fish] #2356003
08/18/17 12:46 PM
08/18/17 12:46 PM
PA.
"Little"John
"Little"John
PA.
I know guys that don't even pre-prime engines and many that do prime their engines don't install a gauge to check priming pressures.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Question on Comp 828-16 roller lifters [Re: pittsburghracer] #2356010
08/18/17 01:01 PM
08/18/17 01:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a gauge but I didn't need to, when it didn't try to rip the drill out of my hands I knew something wasn't right.
