Carter AVS Throttle Shaft Coating #2355372
08/17/17 11:26 AM
08/17/17 11:26 AM
Ohio
carteravs Offline OP
Ohio
Does anyone know what the green coating on the Carter AVS throttle shafts is, and more importantly, who can recoat them?
Thank you
Re: Carter AVS Throttle Shaft Coating [Re: carteravs] #2355401
08/17/17 12:06 PM
08/17/17 12:06 PM
I would call "the carburetor shop" in Eldon Missouri (Google it). He'll know.
Re: Carter AVS Throttle Shaft Coating [Re: RapidRobert] #2355682
08/17/17 09:14 PM
08/17/17 09:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Its teflon. Once removed there is no economical way to replace it. That said, if the shafts are zinc plated and the housing is rebushed with brass bushings it will solve any wear issues so not a huge deal.
Re: Carter AVS Throttle Shaft Coating [Re: carteravs] #2355920
08/18/17 09:48 AM
08/18/17 09:48 AM
E
earlymopar Offline
earlymopar  Offline
E
Contact All American Carburetor in Florida.
http://allamericancarburetor.com/
- EM
