Brake Problem #2354640
08/16/17 02:59 AM
08/16/17 02:59 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Does anyone have a source or part number for the 11x2.5" rear brake drums? I can not find drums for my '66 Plymouth Fury III for the life of me!
Re: Brake Problem [Re: jeebis44] #2354643
08/16/17 03:14 AM
08/16/17 03:14 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I did find some 11x2.5 brake drums for a 66 Chrysler 300 but they have a slightly larger friction surface and have fins whereas the original drums on my Plymouth Fury have no fins and just over 2.5" friction surface. Are these drums interchangeable?
Re: Brake Problem [Re: jeebis44] #2354683
08/16/17 07:51 AM
08/16/17 07:51 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
My 66 parts catalog shows one part number for all 11x2 1/2 rear drums, 2533824
Don't be the exception.
Re: Brake Problem [Re: Supercuda] #2354897
08/16/17 03:33 PM
08/16/17 03:33 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Tried that part number and no one has them in stock. Tried NAPA, Advance, Rockauto, OReilley - where else can I find these?
Re: Brake Problem [Re: jeebis44] #2354940
08/16/17 04:48 PM
08/16/17 04:48 PM
Possibly classic auto
Re: Brake Problem [Re: jeebis44] #2354994
08/16/17 06:18 PM
08/16/17 06:18 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: Brake Problem [Re: mopars4ever] #2355030
08/16/17 07:30 PM
08/16/17 07:30 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Thanks! A bit pricey at $165 though - it really irks me that a regular wear item like brake drums cant be has a the local auto parts store..
Re: Brake Problem [Re: jeebis44] #2355124
08/16/17 10:25 PM
08/16/17 10:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Brake Problem [Re: jeebis44] #2358236
08/22/17 07:19 PM
08/22/17 07:19 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
OK guys, I ordered the new Centric bake drums from Auto Parts Warehouse and OH MY GOD I have rarely seen such an example of shoddy chinese workmanship! Ordered a pair, one came with the counterweight crudely tack-welded on he outside of the drum, the other had no counterweight at all. Neither had the gap between the friction surface and the outside of the drum casing like the factory pieces - just 1 big, crudely cast hunk of iron. I sourced come NOS 11x2.5 drums but they are $175 EACH. Does ANYONE know of another source for these drums? Can I interchange drums from other cars onto my Fury? I'm almost afraid to try these at all - were they actually balanced or did they just tack the weight on wherever they felt to match the picture they had?
Re: Brake Problem [Re: jeebis44] #2358239
08/22/17 07:28 PM
08/22/17 07:28 PM
md
md
The NOS one on ebay for $129 has three weights on it from what I can see. http://www.ebay.com/itm/Rr-Brake-Drum-11...47/172808301092
Re: Brake Problem [Re: jeebis44] #2358251
08/22/17 07:41 PM
08/22/17 07:41 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
The one that came without the counterweight, could it be possible that it is balanced without the need for the weight? Do all drums need that weight on them?
Re: Brake Problem [Re: jeebis44] #2358252
08/22/17 07:41 PM
08/22/17 07:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
the Diplomat's used an 11x2.5" rear drum on cop and taxi setups.
Not sure if it'll work in your case but you have more options available if it will.
Re: Brake Problem [Re: jeebis44] #2358392
08/23/17 12:04 AM
08/23/17 12:04 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm curious what kind of weld you were expecting on that weight !!!
A balance needs a specific weight - which they pick from a selection of weights. The spot weld adds no additional weight so they spot it on and they're done. If they stick welded it on then they'd have to spin it again and take weight off because the stick adds weight. Furthermore, its a cast iron drum and there are very few methods of welding cast iron. Any drum I've ever seen had the weights spot welded on.
Re: Brake Problem [Re: Supercuda] #2358553
08/23/17 01:13 PM
08/23/17 01:13 PM
moparx Offline
moparx  Offline
i'm pretty sure "most" 11x2 1/2" drums will interchange because the axle stand off on the rears are the same. [i think !] the outside appearance will be different, such as fins vs. smooth, fin count and shape, etc. with that said, trucks [with 2WD, 4 1/2" bolt pattern], vans, station wagons, etc. may be something to look at. try the junk yards first for an example before you plunk down the money for new ones. [you may just be lucky enough to score a pair of usable drums] my wagner master catalog lists a different part # for your car vs some of the newer dodge/chrysler, truck/car applications that share the same drum part #.
beer
Re: Brake Problem [Re: jeebis44] #2358568
08/23/17 01:41 PM
08/23/17 01:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Those groves that are missing are to slow down water getting into the brakes. The backing plate goes in there, which makes water have to make three turns to get inside, just slowing it down. These things look like junk.
