68 b-body a/c vacuum canister location #2354447
08/15/17 08:24 PM
08/15/17 08:24 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Anyone have pics where and how it mounts under the battery tray? I don't see any holes in the tray but maybe it's not original.
Thanks!
Re: 68 b-body a/c vacuum canister location [Re: Siba] #2354502
08/15/17 10:33 PM
08/15/17 10:33 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Unless its a Charger. There is no under hood vacuum canister on a B body
And if it is a Charger , it doesnt have anything to do with AC system
Re: 68 b-body a/c vacuum canister location [Re: Siba] #2354523
08/15/17 11:17 PM
08/15/17 11:17 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Really? I thought it was used on b-body (non charger) with a/c. So the HVAC vacuum just goes directly to the manifold?
I guess I'll save $100 on a repop vacuum can then.
Thanks!
Re: 68 b-body a/c vacuum canister location [Re: Siba] #2354811
08/16/17 12:53 PM
08/16/17 12:53 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Not sure about 68, but my 70 Sport Satellite with A/C, has the vacuum canister, bolted under the battery tray - as my car is NON power brakes, the vacuum "t" on the manifold, is just a single small nipple on it. The hose goes from there, ALL the way over to the vacuum canister, and then lots of hose from vacuum canister to the control on the firewall. . . pretty sure your car would have a vacuum canister as well . . . check the FSM . . . oh, and the vacuum canister on my car, looks exactly same as that used on the air grabber cars ! Think it is same as was used on C Bodies as well (check out cbodies in wrecking yards - usually located between fender and inner fender, so well protected)
Re: 68 b-body a/c vacuum canister location [Re: a12rag] #2354876
08/16/17 02:25 PM
08/16/17 02:25 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Yes, this is what I thought and was planning to do the same on my 68 Sport Satellite. My car has manual brakes as well. Any pics of how it mounts to the tray?
