68 b-body a/c vacuum canister location
#2354447
08/15/17 08:24 PM
08/15/17 08:24 PM
Posts: 128 Troy,MI
Siba
Troy,MI
Anyone have pics where and how it mounts under the battery tray? I don't see any holes in the tray but maybe it's not original.
Thanks!
Re: 68 b-body a/c vacuum canister location
[Re: Siba]
#2354523
08/15/17 11:17 PM
08/15/17 11:17 PM
Posts: 128 Troy,MI
Siba
Troy,MI
Really? I thought it was used on b-body (non charger) with a/c. So the HVAC vacuum just goes directly to the manifold?
I guess I'll save $100 on a repop vacuum can then.
Thanks!
[Re: Siba]
#2354811
08/16/17 12:53 PM
08/16/17 12:53 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Not sure about 68, but my 70 Sport Satellite with A/C, has the vacuum canister, bolted under the battery tray - as my car is NON power brakes, the vacuum "t" on the manifold, is just a single small nipple on it. The hose goes from there, ALL the way over to the vacuum canister, and then lots of hose from vacuum canister to the control on the firewall. . . pretty sure your car would have a vacuum canister as well . . . check the FSM . . . oh, and the vacuum canister on my car, looks exactly same as that used on the air grabber cars ! Think it is same as was used on C Bodies as well (check out cbodies in wrecking yards - usually located between fender and inner fender, so well protected)
[Re: a12rag]
#2354876
08/16/17 02:25 PM
08/16/17 02:25 PM
Posts: 128 Troy,MI
Siba
Troy,MI
Not sure about 68, but my 70 Sport Satellite with A/C, has the vacuum canister, bolted under the battery tray - as my car is NON power brakes, the vacuum "t" on the manifold, is just a single small nipple on it. The hose goes from there, ALL the way over to the vacuum canister, and then lots of hose from vacuum canister to the control on the firewall. . . pretty sure your car would have a vacuum canister as well . . . check the FSM . . . oh, and the vacuum canister on my car, looks exactly same as that used on the air grabber cars ! Think it is same as was used on C Bodies as well (check out cbodies in wrecking yards - usually located between fender and inner fender, so well protected) Yes, this is what I thought and was planning to do the same on my 68 Sport Satellite. My car has manual brakes as well. Any pics of how it mounts to the tray?
