Re: 440 Exhaust Drone after Head,Intake and Carb Change
[Re: p d'ro]
#2354371
08/15/17 05:52 PM
08/15/17 05:52 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Hi,
My exhaust is a custom welded job with H pipe and Dynomax Super Turbo mufflers. No drone with Eddy 750, stock heads and intake. Switched to Eddy Performer heads, CH4B intake, and Holley 770 Avenger. It was significant before carb change but even more noticeable after. Now pretty annoying drone at low to mid RPMs. Previously switched from some Hooker chambered mufflers to rid a drone. Any ideas?
Thanks, Pete Check the ign timing , Vacuum advance?
[Re: p d'ro]
#2354372
08/15/17 05:54 PM
08/15/17 05:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Odds are when you swapped the heads the exhaust touched somewhere, look closely, everywhere.
[Re: BigBlockMopar]
#2354413
08/15/17 07:15 PM
08/15/17 07:15 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
Very likely the exhaust is just louder now w/ the added power.
[Re: p d'ro]
#2354451
08/15/17 08:34 PM
08/15/17 08:34 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
The drone is a resonant frequency that can change with the length of exhaust and other factors. I've had it come and go with a simple change of mufflers, same length, different brand/model. How to get rid of it? Sometimes a muffler change will help, sometimes changing the length of the exhaust(harder to do).
dstryr, since 1986.
[Re: Siba]
#2354501
08/15/17 10:30 PM
08/15/17 10:30 PM
RapidRobert
so you are running manifolds? If so, adding resonators in the tailpipes will fix it. Agreed, adding some "cherrybomb" brand glasspacks alongside the leaf springs will work wonders. they are cheap/louvers are punched outward/they do not neck down where the nipples are welded to the case. I run em on my truck (my only mufflers) & they do work.
