440 Exhaust Drone after Head,Intake and Carb Change #2354357
08/15/17 05:10 PM
08/15/17 05:10 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Hi,
My exhaust is a custom welded job with H pipe and Dynomax Super Turbo mufflers. No drone with Eddy 750, stock heads and intake. Switched to Eddy Performer heads, CH4B intake, and Holley 770 Avenger. It was significant before carb change but even more noticeable after. Now pretty annoying drone at low to mid RPMs. Previously switched from some Hooker chambered mufflers to rid a drone. Any ideas?
Thanks, Pete
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: p d'ro] #2354371
08/15/17 05:52 PM
08/15/17 05:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By p d'ro
Hi,
Thanks, Pete
Check the ign timing , Vacuum advance?
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: p d'ro] #2354372
08/15/17 05:54 PM
08/15/17 05:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Odds are when you swapped the heads the exhaust touched somewhere, look closely, everywhere.
Don't be the exception.
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: p d'ro] #2354390
08/15/17 06:37 PM
08/15/17 06:37 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Some folks confuse 'drone' with just a loud(er) exhaust noise in certain rpm-ranges.
IMO actual 'droning' is when other nearby parts like sheetmetal or interior parts start to vibrate along with the exhaust and add their own noise to the exhaust.
It's also quite possible ofcourse the new intake and cylinder heads create more cylinder pressure now which increased the exhaust noiselevel a bit.
I also believe the type of exhaust hanger used can also increase interior noises by transfering exhaust vibrations to the body.
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: BigBlockMopar] #2354413
08/15/17 07:15 PM
08/15/17 07:15 PM
an8sec70cuda Offline
iagree Very likely the exhaust is just louder now w/ the added power.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: p d'ro] #2354449
08/15/17 08:30 PM
08/15/17 08:30 PM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
so you are running manifolds? If so, adding resonators in the tailpipes will fix it.
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: p d'ro] #2354451
08/15/17 08:34 PM
08/15/17 08:34 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
The drone is a resonant frequency that can change with the length of exhaust and other factors. I've had it come and go with a simple change of mufflers, same length, different brand/model. How to get rid of it? Sometimes a muffler change will help, sometimes changing the length of the exhaust(harder to do).
dstryr, since 1986.
Re: 440 Exhaust Drone after Head,Intake and Carb Change [Re: Siba] #2354501
08/15/17 10:30 PM
08/15/17 10:30 PM
Agreed, adding some "cherrybomb" brand glasspacks alongside the leaf springs will work wonders. they are cheap/louvers are punched outward/they do not neck down where the nipples are welded to the case. I run em on my truck (my only mufflers) & they do work.
