Paxton SN93 Supercharger on SBM??? #235397
02/24/09 10:08 PM
02/24/09 10:08 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
So I have an SN93 Supercharger I am putting on a small block stroker and was wondering if anyone has messed with this charger on any small block or big block applications. Right now I am in need of brackets, and wanted to know if anyone knows of sources for the brackets? The goal is an E85, blow thru carb set up. Mainly a keep it simple motto...
I currently have the magnum bracket but it does not fit, and would rather not cut it, if I sell the kit someday.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Paxton SN93 Supercharger on SBM??? [Re: wldtm] #235398
02/25/09 12:24 AM
02/25/09 12:24 AM
IL
Dart451 Offline
Dart451  Offline
IL
That sucks didn't realize the magnum had different mounting brackets. I say cut it up and have fun!
Re: Paxton SN93 Supercharger on SBM??? [Re: wldtm] #235399
02/25/09 12:31 AM
02/25/09 12:31 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Justin
I've had friends that used that exact blower and they seize-up a lot. Actually just about all the Paxton's had that problem.
Re: Paxton SN93 Supercharger on SBM??? [Re: EvilB1Dart] #235400
02/25/09 01:07 AM
02/25/09 01:07 AM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
The older SN series were known for that, they use a ball drive setup. The newer Novi series are much better, they're gear driven.
Re: Paxton SN93 Supercharger on SBM??? [Re: bad360rt] #235401
02/25/09 08:09 AM
02/25/09 08:09 AM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Well we (Dart451) did some trading for it. I wondered if they mounted differently, but I wasnt worried about it.
Talk to paxton and they said the Mr Norms kit from back in the day has the same mouting as the SN93. Just need to figure out who makes the bracket or fab my own.
I did check the rotational torque per my conversation with paradise wheel, and it was dead on in the middle of the spec. Maybe its not worth it.
Will do some more checking...
Justin
Re: Paxton SN93 Supercharger on SBM??? [Re: wldtm] #235402
02/25/09 08:23 AM
02/25/09 08:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I ran an SN2000 on a 440 w/ no problems. Mine came w/ mouning hardware for a Chevy, no biggie it was steel so I cut some and welded some to it. Then I had the crank pulley drilled out by a machine shop and whaaallla...
Re: Paxton SN93 Supercharger on SBM??? [Re: Mr.Yuck] #235403
02/25/09 08:47 AM
02/25/09 08:47 AM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Paxton just came out with a new kit for the small block Mopar, maybe these would work?
Re: Paxton SN93 Supercharger on SBM??? [Re: hemi471] #235404
02/25/09 09:03 AM
02/25/09 09:03 AM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Thanks for posting the pics. I remembered the pic of the big block. Right now thats what I am leaning towards. What did you do for the tensioner?
Those were the brackets I originally called paxton about, but no luck. They wont work. Thanks folks...
Justin M
Re: Paxton SN93 Supercharger on SBM??? [Re: wldtm] #235405
02/25/09 09:56 AM
02/25/09 09:56 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The tensioner is a non-spring loaded type...push it into place and lock it down. I made a template out of 3/8 ply wood (same size as the steel bracket) Then I cut the mounting ears off the chevy unit and welded mine on. (mounts where the PS was) When I do it again I'll mount it pass side so I can keep the PS and battery up front.
Re: Paxton SN93 Supercharger on SBM??? [Re: Mr.Yuck] #235406
02/28/09 12:48 AM
02/28/09 12:48 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
So how much power is a old school Mr Norms blower capable of supporting?- I'm under the understanding that none of the SN series 89,92,93 really put out all that much cfm -even with the upgraded impeller. Can anybody elaborate on how it would work on my 416 with W2's, Victor intake, tti step headers. Is this combo starting off with too much airflow to make this old blower effective?
Re: Paxton SN93 Supercharger on SBM??? [Re: 72demon416] #235407
02/28/09 01:09 AM
02/28/09 01:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good heads sure wont hurt the out put, its still up to
the compressor if it has the volume(which I dont
know that unit)
Re: Paxton SN93 Supercharger on SBM??? [Re: MR_P_BODY] #235408
02/28/09 10:49 AM
02/28/09 10:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
know that unit)
You can use a modified impeller to increase the airflow. I'd call Craig at Paradise Wheels in Cali. He bought all of the Pazton stuff up. A better S/C might be the SN2000. I used it on a mild 440. Dropped about a full second off my et, picked up 10mph and didn't touch the motor.
Re: Paxton SN93 Supercharger on SBM??? [Re: Mr.Yuck] #235409
02/28/09 12:09 PM
02/28/09 12:09 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Has anybody ever seen the Cfm or max horsepower ratings for a sn60 or the sn2000- I sure can't seem to find any on the net
Re: Paxton SN93 Supercharger on SBM??? [Re: 72demon416] #235410
02/28/09 09:03 PM
02/28/09 09:03 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I found out today that you can swap the back half and impeller from a paxton VR4 model blower and SUBSTANTIALLY increase the cfm and boost pressure on these older SN series blowers. Because of this you don't need to reduce the pulley size and over-rev it- thus burning the unit up prematurely
Re: Paxton SN93 Supercharger on SBM??? [Re: 72demon416] #235411
02/28/09 09:17 PM
02/28/09 09:17 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
http://www.superchargerhelp.com/showthread.php?t=9584
not sure this will help but you can ask here also.
Re: Paxton SN93 Supercharger on SBM??? [Re: blownzoom440] #235412
02/28/09 09:36 PM
02/28/09 09:36 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
got a linky to that info?
that would be some good info to read.
Re: Paxton SN93 Supercharger on SBM??? [Re: wldtm] #235413
02/28/09 09:58 PM
02/28/09 09:58 PM
ELYRIA,OH
ELYRIA,OH
at superchargerhelp.com
oops you ment above info.
Re: Paxton SN93 Supercharger on SBM??? [Re: blownzoom440] #235414
03/01/09 01:02 AM
03/01/09 01:02 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Yea, I read that article this morning- that's what got me on this hunt for VR4 info...
