Paxton SN93 Supercharger on SBM???
#235397
02/24/09 10:08 PM
02/24/09 10:08 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
So I have an SN93 Supercharger I am putting on a small block stroker and was wondering if anyone has messed with this charger on any small block or big block applications. Right now I am in need of brackets, and wanted to know if anyone knows of sources for the brackets? The goal is an E85, blow thru carb set up. Mainly a keep it simple motto...
I currently have the magnum bracket but it does not fit, and would rather not cut it, if I sell the kit someday.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
Re: Paxton SN93 Supercharger on SBM???
[Re: wldtm]
#235399
02/25/09 12:31 AM
02/25/09 12:31 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Justin
I've had friends that used that exact blower and they seize-up a lot. Actually just about all the Paxton's had that problem.
[Re: EvilB1Dart]
#235400
02/25/09 01:07 AM
02/25/09 01:07 AM
Posts: 274 Greenville, SC
bad360rt
Greenville, SC
The older SN series were known for that, they use a ball drive setup. The newer Novi series are much better, they're gear driven.
[Re: bad360rt]
#235401
02/25/09 08:09 AM
02/25/09 08:09 AM
wldtm
Dayton, Ohio
Well we (Dart451) did some trading for it. I wondered if they mounted differently, but I wasnt worried about it.
Talk to paxton and they said the Mr Norms kit from back in the day has the same mouting as the SN93. Just need to figure out who makes the bracket or fab my own.
I did check the rotational torque per my conversation with paradise wheel, and it was dead on in the middle of the spec. Maybe its not worth it.
Will do some more checking...
Justin
PM for details
[Re: hemi471]
#235404
02/25/09 09:03 AM
02/25/09 09:03 AM
wldtm
Dayton, Ohio
Thanks for posting the pics. I remembered the pic of the big block. Right now thats what I am leaning towards. What did you do for the tensioner?
Those were the brackets I originally called paxton about, but no luck. They wont work. Thanks folks...
Justin M
PM for details
[Re: 72demon416]
#235407
02/28/09 01:09 AM
02/28/09 01:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So how much power is a old school Mr Norms blower capable of supporting?- I'm under the understanding that none of the SN series 89,92,93 really put out all that much cfm -even with the upgraded impeller. Can anybody elaborate on how it would work on my 416 with W2's, Victor intake, tti step headers. Is this combo starting off with too much airflow to make this old blower effective?
Good heads sure wont hurt the out put, its still up to the compressor if it has the volume(which I dont know that unit)
[Re: MR_P_BODY]
#235408
02/28/09 10:49 AM
02/28/09 10:49 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
You can use a modified impeller to increase the airflow. I'd call Craig at Paradise Wheels in Cali. He bought all of the Pazton stuff up. A better S/C might be the SN2000. I used it on a mild 440. Dropped about a full second off my et, picked up 10mph and didn't touch the motor.
[Re: blownzoom440]
#235412
02/28/09 09:36 PM
02/28/09 09:36 PM
wldtm
Dayton, Ohio
got a linky to that info?
that would be some good info to read.
PM for details
