1971 'Cuda Hood Pin Cables scuffing the paint
#2354034
08/15/17 01:18 AM
08/15/17 01:18 AM
Posts: 32 Metro Detroit,Michigan
isettakurt
Hello, My '71 Cuda has the hood pin option.I have the proper plastic coated factory type cables.But they scuff the paint when I drive over 50 mph. Besides removing them what would be a good fix. Thanks Kurt isettakurt@gmail.com
Re: 1971 'Cuda Hood Pin Cables scuffing the paint
[Re: isettakurt]
#2354128
08/15/17 11:12 AM
08/15/17 11:12 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I always tuck them inside rad support for driving. Then pull them out for shows etc. I know this is not how there intended to be used but did not want to deal with what you describe.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: isettakurt]
#2354202
08/15/17 01:14 PM
08/15/17 01:14 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I twist them so they stand up and off the hood up through normal freeway speeds, but as the car approaches 125 mph they do start to flatten out on the header panel. At 150+ mph they are squashed down pretty hard, so I try to keep it under 100 mph.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
