Tig welding question #2351480
08/09/17 06:38 PM
08/09/17 06:38 PM
MN
JERICOGTX Offline OP
MN
What filler rod can I use to attach sheet metal to the rollcage?
69 GTX 68 Road Runner
Re: Tig welding question [Re: JERICOGTX] #2351495
08/09/17 07:01 PM
08/09/17 07:01 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You can use .030" 4043 or a small silicon bronze rod should work too.
Re: Tig welding question [Re: justinp61] #2351503
08/09/17 07:12 PM
08/09/17 07:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
He said sheet metal?, didn't mention material, likely for steel a 70 series is fine.
Re: Tig welding question [Re: JERICOGTX] #2351528
08/09/17 08:04 PM
08/09/17 08:04 PM
Out West
408strokerdart Offline
Out West
4043 is aluminum. I assume you are welding steel to steel so like jcc said 70 series is fine, but I actually prefer to use silicon bronze as it has a lower melting point and seems to require less total heat input which is always a good thing on sheetmetal.
Re: Tig welding question [Re: JERICOGTX] #2351541
08/09/17 08:53 PM
08/09/17 08:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Er70s2
Re: Tig welding question [Re: JERICOGTX] #2351546
08/09/17 08:58 PM
08/09/17 08:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sheet metal, I assume steel. Maybe 20 or 22 gauge. Silicon bronze. Lower melting temp, lower tensile strength than ER70. It has a little "give" which helps prevent the sheet metal from cracking at the weld.
Re: Tig welding question [Re: 408strokerdart] #2351576
08/09/17 10:09 PM
08/09/17 10:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes 4043 is aluminum. I don't know what I was thinking, night shifts are getting to me. lol
ER70s or silicon bronze.
Re: Tig welding question [Re: justinp61] #2351593
08/09/17 10:47 PM
08/09/17 10:47 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Silicon bronze.
Re: Tig welding question [Re: JERICOGTX] #2351743
08/10/17 09:00 AM
08/10/17 09:00 AM
MN
MN
Thanks everyone. I'll pick up some silicon bronze tonight.
Jeff
Re: Tig welding question [Re: JERICOGTX] #2351899
08/10/17 02:39 PM
08/10/17 02:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I never had a problem just stitch welding, do you have big gaps? If so make some 1/2x1/2 thin gauge angle, punch some 1/8 holes for the mig or spot weld.
