Tig welding question
#2351480
08/09/17 06:38 PM
08/09/17 06:38 PM
Posts: 10,029 MN
JERICOGTX
MN
What filler rod can I use to attach sheet metal to the rollcage?
69 GTX
68 Road Runner
Re: Tig welding question
[Re: justinp61]
#2351503
08/09/17 07:12 PM
08/09/17 07:12 PM
Posts: 22,696 Bitopia
jcc
Bitopia
He said sheet metal?, didn't mention material, likely for steel a 70 series is fine.
[Re: JERICOGTX]
#2351546
08/09/17 08:58 PM
08/09/17 08:58 PM
Posts: 11,590 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sheet metal, I assume steel. Maybe 20 or 22 gauge. Silicon bronze. Lower melting temp, lower tensile strength than ER70. It has a little "give" which helps prevent the sheet metal from cracking at the weld.
[Re: JERICOGTX]
#2351743
08/10/17 09:00 AM
08/10/17 09:00 AM
Posts: 10,029 MN
JERICOGTX
MN
Thanks everyone. I'll pick up some silicon bronze tonight.
Jeff
69 GTX
68 Road Runner
