engine starter shopping #2350625
08/08/17 12:03 PM
08/08/17 12:03 PM
illinois
dodgeram1998 Offline OP
illinois
I keep goin thru the 90ish dodge truck OEM starter and ruining them with about 25-30 cranks , 440 13.8 cr
Its nonsense to keep replaceing,
whats the proven starter out there
Re: engine starter shopping [Re: dodgeram1998] #2350627
08/08/17 12:06 PM
08/08/17 12:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You must have a problem.My mini for a 360 Ram reman has been on my 12.5 440 for at least 17 years.Still starts like a /6.There is a difference in the minis.The 360 one is rated higher.If you are burning them up you have to be seeing excessive amps.Mine is even captured by the headers.never a problem.Rocky
Chrysler Firepower
Re: engine starter shopping [Re: dodgeram1998] #2350630
08/08/17 12:10 PM
08/08/17 12:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your set up.. do you run a separate switch
for the ignition (1 for cranking then hit the
ignition)... whats the cranking pressure.. I assume
it starts cold but a hard time when hot
wave
Re: engine starter shopping [Re: dodgeram1998] #2350631
08/08/17 12:11 PM
08/08/17 12:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Kinda funny how some guys have issues with this and some don't. My last starter cost my 69.00 ordered from Advance Auto for a 1995 small block Dodge truck, and is going on its 4th year. I spend a fair amount of time shinning mine and getting it right because I have different set-ups on my cars. Some have powerglide adapter plates and some have UltraBells so it really makes you pay attention and just not throw it on like some guys do. Good grounding is another issue for some.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: engine starter shopping [Re: pittsburghracer] #2350641
08/08/17 12:26 PM
08/08/17 12:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use RobbMc starters, never any issues. up
http://www.robbmcperformance.com/products/starter_home.html
JB Rhinehart, Realist
A-Body's RULE!
Re: engine starter shopping [Re: pittsburghracer] #2350682
08/08/17 01:18 PM
08/08/17 01:18 PM
illinois
illinois
Thanks what kind of compression on your engine
Re: engine starter shopping [Re: dodgeram1998] #2350683
08/08/17 01:18 PM
08/08/17 01:18 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Powermaster starters for me... They have a couple different prices ranges for tight wads like me... and their customer service is the best I've seen in quite awhile..
Sent in my 12V alt to be upgraded to 16V... I think it was like $35.00 which included return shipping..
Sent in a broken starter that had the housing crack... A week later a new starter was at my doorstep... and at no cost to me..
Re: engine starter shopping [Re: dodgeram1998] #2350694
08/08/17 01:28 PM
08/08/17 01:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I have run stock mini starters on my junk with no issues. My last one accidently got knocked off my tool box and cracked. I happened to have a powermaster I had picked up in some deal and threw it in there and never a problem with it either.
I too believe ALOT Of starter issues come from poor grounds on the car. Just went through this on my Status. We had some issues cranking the engine and come to find out one of the crimps was loose on the battery ground. Fixed that a viola problem solved.
Re: engine starter shopping [Re: dodgeram1998] #2350698
08/08/17 01:36 PM
08/08/17 01:36 PM
PA.
"Little"John
"Little"John
PA.
My current build is app 12.5 but running alcohol I don't spend a lot of time getting real accurate numbers. I ran the same exact starters in my 572 and 500 big blocks that ran in the 8's on race gas with higher compression. My big point was pay attention to details. Some of these starters need attention out of the box. A quick clean-up of the mounting surface with a flat file goes a long way in not only cleaning it but squaring it up. Not as much over the last two years but I run the crap out of my stuff and it doesn't sit around much. Good grounding, GOOD power connections go a long way. Our stock starters are miles above the old Chevy stuff if we set them up right. Aluminum is not a good ground and is a big reason mobile homes used to burn to the ground so often. Anything to save a buck was their moto.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: engine starter shopping [Re: dodgeram1998] #2350700
08/08/17 01:37 PM
08/08/17 01:37 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I use Napa replacements with no problem but I also use a start retard. They really wiz bang with 16 volts.
Re: engine starter shopping [Re: dodgeram1998] #2350750
08/08/17 03:14 PM
08/08/17 03:14 PM
illinois
illinois
My problem is never the electrical side of operations ,motor spins yet the starter drive always fails to engage or engagee to spin my engine, i will have to inspect with detail the clearances and squareness of drive gear .
Re: engine starter shopping [Re: MR_P_BODY] #2350753
08/08/17 03:15 PM
08/08/17 03:15 PM
illinois
illinois
Separate switch for igniton, crank up to spin motor then activate ignition to fire
Re: engine starter shopping [Re: dodgeram1998] #2350770
08/08/17 03:42 PM
08/08/17 03:42 PM
PA.
"Little"John
"Little"John
PA.
Some of my set-ups have a shim as thick as this.
https://www.summitracing.com/parts/qti-rm-6024
But more are thin which I used to make till I found these.
https://www.summitracing.com/parts/jpt-92472
http://www.jegs.com/i/JW-Performance/564/92472/10002/-1
They will direct ship to you so if you need these they usally come pretty quick. I'm going to order another kit as I'm getting low. If you call JW Transmission they can give you more info.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: engine starter shopping [Re: dodgeram1998] #2350783
08/08/17 03:52 PM
08/08/17 03:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Meziere is high quality stuff. It cranked my 12.5 cr 572 Hemi like the spark plugs were out.
2011 Drag Pak Challenger
Re: engine starter shopping [Re: rickseeman] #2350845
08/08/17 05:36 PM
08/08/17 05:36 PM
illinois
illinois
Lol
Re: engine starter shopping [Re: dodgeram1998] #2351418
08/09/17 04:39 PM
08/09/17 04:39 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not just poor grounds but bad cables.That and cables that are too small.I run 1 gauge on my 440.When I ran the stock Mopars ones always had a problem slow cranking.That and just because cables look good on the outside they corrode inside.Cant say how many I saw at the shop in 30 years.Weak batterys will also kill a starter.Rocky
Chrysler Firepower
Re: engine starter shopping [Re: dodgeram1998] #2351429
08/09/17 05:03 PM
08/09/17 05:03 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I just finished going through this issue. The motor would get hot and she wouldn't crank. Well.. after taking advice from a lot of the guys here I put a fresh starter on, made sure all the positive side cables were getting good connection and ran a heavy ground cable from the battery in the trunk to the bell housing. Also made sure the battery had good cranking amps. Now she spins like a champ (557" 14:1 comp) (Chrysler mini)
Re: engine starter shopping [Re: therocks] #2351855
08/10/17 01:28 PM
08/10/17 01:28 PM
moparx Offline
moparx  Offline
iagree
and above all, DON'T use those cheap-o battery terminals that retain the cable with the bolt on straps ! flame i hate those things with a passion ! more starting woes are created by using those dam things than you could imagine ! did i mention i HATE those things ?
beer
Re: engine starter shopping [Re: pittsburghracer] #2352257
08/11/17 02:04 AM
08/11/17 02:04 AM
illinois
illinois
finally got out to garage, to inspect starter, the nose is installed in its registry hole, not good but .040 clearance from starter gear to ring gear, shimmed out starter to .125 clearance and while under car with some cranking the starter,, the starter gear a couple time didn't meshed with ring gear , plus the starter gear wouldn't retract, some kind of alignment problem , I believe I have to cut out the midplate in the starter mounting area to square up starter and get my proper alignment . well see tomorrow
I have a ultra bell housing and mid plate
Re: engine starter shopping [Re: dodgeram1998] #2352523
08/11/17 06:28 PM
08/11/17 06:28 PM
PA.
"Little"John
"Little"John
PA.
Here's that starter shim pack from JW transmissions if you guys are ever looking. 5 nice heavy duty shins and the nose piece some guys need
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
