Page 3 of 3 1 2 3
Re: Buy viking or Afco [Re: dodgeram1998] #2342621
07/24/17 07:21 PM
07/24/17 07:21 PM
illinois
dodgeram1998 Offline OP
illinois
afco 3850 for the rear
3855m for the front .
afco recommended me there 125# springs
with a guesstimate of 1600 pounds on the rear
my car is 3375 with me ready to race
what size springs do other duster guys use,
Re: Buy viking or Afco [Re: dodgeram1998] #2342623
07/24/17 07:26 PM
07/24/17 07:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The 125's will work well for you at that weight.
69 GTX 68 Road Runner
Re: Buy viking or Afco [Re: JERICOGTX] #2342780
07/24/17 11:08 PM
07/24/17 11:08 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
imo strange has been great on my car and some other cars i have helped set up for radials and offers free stiffer valving at no extra cost for cars over a 1000 hp if you run a slick shocks do not need to be as good
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Buy viking or Afco [Re: dodgeram1998] #2342928
07/25/17 07:52 AM
07/25/17 07:52 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Did you do your home work and measure the length required for your car???? I would not just go with there recommended shock length, Take the time and measure.
Re: Buy viking or Afco [Re: dodgeram1998] #2342979
07/25/17 11:45 AM
07/25/17 11:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We run Strange DA on the rear of the heads up car. They do have their Pro Mod valving in them too. Been great for us and we are handcuffed by running a very short shock because of the body style of the car.
As for spring rate you just need enough spring to hold the car up with the shock at ride height.
Re: Buy viking or Afco [Re: dodgeram1998] #2349980
08/07/17 11:44 AM
08/07/17 11:44 AM
illinois
illinois
bought the afcos
duster 3375 new best 60ft 1.33 tb rpm4500
12.5 psi 29.5 x 10.5
hit 14 click from full stiffness
bump 9 click from full stiffness
I didn't even try other settings car pulled wheels 50ft
NOW on to the other issue jet changes didn't affect mph
131.66mph im losing 4-5mph due to something ? almost @ 1000ft it just wont pull more rpm it seems like it hits a wall
happy with the afcos
Re: Buy viking or Afco [Re: dodgeram1998] #2350020
08/07/17 01:07 PM
08/07/17 01:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hood scoop or no? Fuel pressure on big end? RPM where it is occuring? More info on the combo and whats going on up top will help.
Re: Buy viking or Afco [Re: Al_Alguire] #2350308
08/07/17 09:28 PM
08/07/17 09:28 PM
illinois
illinois
no hood scoop, rock solid pressure 5.5 psi, isky 700# over the nose pressure on 276@.050 .630 lift.
1.33 sixty
1-2 7000rpm,
2-3 short shifted at 6300
mph still stays the same
more info coming
Re: Buy viking or Afco [Re: dodgeram1998] #2350312
08/07/17 09:41 PM
08/07/17 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What carb and what needle and seats.. need more
info to help you
wave
Re: Buy viking or Afco [Re: MR_P_BODY] #2350508
08/08/17 03:06 AM
08/08/17 03:06 AM
illinois
illinois
1.33 60
4.042 330
6.35 1/8th@ 106.25mph
10.07 1/4@ 131.66mph
hp innovation e 85 carb PLEASED with .130 seats
1050 dommy relative flat fuel curve entire pass of .077 thru .086 lambda with jetting changes never changed mph at the stripe of 131.66 every time?
timing locked every pass.
car has run previous 9.92 with home built QFT 1050/4150 better weather ? cant compare don't have the data
making pass at just before 1000ft it seems to stay stuck on 6700 rpm and cross at 6700
Page 3 of 3 1 2 3
