T/A & AAR Power steering pulley & Pump
#234800
02/24/09 01:52 PM
02/24/09 01:52 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Does anyone have a picture of the correct power steering pulley for the T/A cars? Also I think I have only seen the federal pumps with the oil cooler used on these cars, is that correct as well?
Al & Sheila
Re: T/A & AAR Power steering pulley & Pump
[Re: Alaskan_TA]
#234804
02/25/09 02:20 PM
02/25/09 02:20 PM
Posts: 15,491 the boonies
aarcuda
the boonies
This is a fast ratio box. I do not know if the std. power steering box is the same, you could get both styles on a T/A.
ya, thats the one i have right there
[Re: 6pkaar]
#234806
02/25/09 03:32 PM
02/25/09 03:32 PM
3twos
Minnesota
I would almost be guessing that the fan type pulley was used due to the power steering fluid cooler used on these cars but that is a guess. I know where you can get a whole pump,pulley and cooler if you are interested send me a pm
Al & Sheila
[Re: 3twos]
#234811
03/04/09 12:19 AM
03/04/09 12:19 AM
Posts: 29,655 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Barry,
Are you saying you could get both pumps on the t/a cars? I think I have only seen federal pumps on them. Also is it correct that some t/a cars had power steering with fast ratio steering box, some had manual steering and some had just regular power steering without the fast ratio box?
I meant Fast Ratio & the Std. Ratio power boxes.
T/As came with either of those two or manual steering.
AARs came with the manual box or the Fast Ratio Power box. I have not seen an AAR yet with a std. ratio power box.
Edit;
Just to clarify that a little further, when I say "I have not seen an AAR yet with a std. ratio power box", I am talking about seeing it on an AAR broadcast sheet, not on the car itself.
