1970 Cuda Deck Lid #2345835
07/30/17 07:08 PM
07/30/17 07:08 PM
NY, NASSAU
70CUDACONVERT Offline OP
NY, NASSAU
It was brought to my attention that there are differences with 1970 Deck Lids. So I am told. At Carlisle I was able to observe that some Deck Lids on the back have 4 holes to accommodate the optional rear wing (70 option only) and others that have 2. My 70 Cuda does not have the 4 holes. My question is what is the correct Deck Lid if there is any differences in the Deck Lid for 70 E Bodies only? Any input will be of great help.
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345853
07/30/17 07:47 PM
07/30/17 07:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 without cutouts and 70 with spoiler (go-wing)
Re: 1970 Cuda Deck Lid [Re: DAYCLONA] #2345856
07/30/17 07:49 PM
07/30/17 07:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 AAR (white) and 71-4 (green) below
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345860
07/30/17 07:56 PM
07/30/17 07:56 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Hi Gary!!
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345877
07/30/17 08:43 PM
07/30/17 08:43 PM
NY, NASSAU
NY, NASSAU
Thanks for the great pictures and explanation.I thought the GO WING was a 70 option. Then I can understand to have only 2 holes after that. So how was it determined what car will have the proper Deck Lid installed? I have a late production car.
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345879
07/30/17 08:45 PM
07/30/17 08:45 PM
NY, NASSAU
NY, NASSAU
I don't know who said HI. But I hope you can let me know. Obviously you know my car.
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345887
07/30/17 09:11 PM
07/30/17 09:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Early - Luggage rack provisions only
Mid year (December-ish) Luggage rack & J81 spoiler provisions.
Spring - Luggage rack, J81 spoiler & J82 spoiler provisions.
This last style was used into the 1971 model year & then for '72 it was phased out.
I have seen ONE early '72 with it so far though.
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345894
07/30/17 09:22 PM
07/30/17 09:22 PM
NY, NASSAU
NY, NASSAU
To understand this correctly. The 4 hole cut outs were for the luggage provision only for early productions and so on how you described it. Without those options stated it should have the standard cut outs.
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345927
07/30/17 10:22 PM
07/30/17 10:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
your late-'70 model year 'cuda (after Feb. '70 production) should have the "white" decklid pictured above
Re: 1970 Cuda Deck Lid [Re: 6bblgt] #2345955
07/30/17 10:55 PM
07/30/17 10:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Unless it did not.
Leftovers were used as needed.
To the OP - do you have any reason to suspect that your deck lid is not original to your car?
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2345983
07/30/17 11:40 PM
07/30/17 11:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...70 with luggage rack provisions
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2346070
07/31/17 04:09 AM
07/31/17 04:09 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There are 3 different deck lids for 70 as pointed out
Re: 1970 Cuda Deck Lid [Re: Morty426] #2346113
07/31/17 10:40 AM
07/31/17 10:40 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
iagree
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1970 Cuda Deck Lid [Re: moparmarks] #2346584
08/01/17 09:55 AM
08/01/17 09:55 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Good info, I just acquired a Cuda deck lid, now I will know the application! up
JB Rhinehart, Realist
A-Body's RULE!
Re: 1970 Cuda Deck Lid [Re: Rhinodart] #2347264
08/02/17 01:34 PM
08/02/17 01:34 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Ok, what does this one go on then? Cut-outs on one side only. Probably 72-74 I asssume. shruggy
A-Body's RULE!
Re: 1970 Cuda Deck Lid [Re: 70CUDACONVERT] #2347603
08/02/17 11:53 PM
08/02/17 11:53 PM
NY, NASSAU
NY, NASSAU
The only reason I am questioning the correct deck lid is because another 1970 Cuda owner brought it to my attention.It just so happens he has the same one I have. But he was told about the 4 hole cut out was correct. He has an early production and mine is a late production. I don't think it was replaced. The first picture posted is the one I have.
Re: 1970 Cuda Deck Lid [Re: Rhinodart] #2347871
08/03/17 02:06 PM
08/03/17 02:06 PM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
That matches my 73.
Re: 1970 Cuda Deck Lid [Re: Rhinodart] #2347951
08/03/17 03:43 PM
08/03/17 03:43 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
You are correct, it is the standard one size for all applications 72-4 lid. Unless you ordered a luggage rack, then it would have the four holes with studs from the factory. But ALL 72-4 lids have that same underside.
Re: 1970 Cuda Deck Lid [Re: m46rat] #2348201
08/03/17 11:24 PM
08/03/17 11:24 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So what is the big hole for? shruggy
A-Body's RULE!
Re: 1970 Cuda Deck Lid [Re: Rhinodart] #2348242
08/04/17 12:47 AM
08/04/17 12:47 AM
moparmarks Offline
moparmarks  Offline
Only thing I can think of is to make it easier to get the trunk light wire around that corner. ????? shruggy
Desert Mopar Metal
Grand Jct. CO
970-261-7039
