Re: 1970 Cuda Deck Lid
[Re: 70CUDACONVERT]
#2345853
07/30/17 07:47 PM
07/30/17 07:47 PM
Posts: 18,157 Mass
DAYCLONA
Mass
It was brought to my attention that there are differences with 1970 Deck Lids. So I am told. At Carlisle I was able to observe that some Deck Lids on the back have 4 holes to accommodate the optional rear wing (70 option only) and others that have 2. My 70 Cuda does not have the 4 holes. My question is what is the correct Deck Lid if there is any differences in the Deck Lid for 70 E Bodies only? Any input will be of great help. 70 without cutouts and 70 with spoiler (go-wing)
[Re: 70CUDACONVERT]
#2345860
07/30/17 07:56 PM
07/30/17 07:56 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
It was brought to my attention that there are differences with 1970 Deck Lids. So I am told. At Carlisle I was able to observe that some Deck Lids on the back have 4 holes to accommodate the optional rear wing (70 option only) and others that have 2. My 70 Cuda does not have the 4 holes. My question is what is the correct Deck Lid if there is any differences in the Deck Lid for 70 E Bodies only? Any input will be of great help. Hi Gary!!
[Re: 6bblgt]
#2345955
07/30/17 10:55 PM
07/30/17 10:55 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
your late-'70 model year 'cuda (after Feb. '70 production) should have the "white" decklid pictured above Unless it did not. Leftovers were used as needed. To the OP - do you have any reason to suspect that your deck lid is not original to your car?
[Re: 70CUDACONVERT]
#2345983
07/30/17 11:40 PM
07/30/17 11:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
To understand this correctly. The 4 hole cut outs were for the luggage provision only for early productions and so on how you described it. Without those options stated it should have the standard cut outs. ...70 with luggage rack provisions
[Re: Rhinodart]
#2347264
08/02/17 01:34 PM
08/02/17 01:34 PM
Posts: 43,596 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Ok, what does this one go on then? Cut-outs on one side only. Probably 72-74 I asssume.
JB Rhinehart, Realist
A-Body's RULE!
