Anybody run a 1050 4150?
#2346850
08/01/17 07:33 PM
08/01/17 07:33 PM
Posts: 2,141 junction city oregon
viperblue72
I decided to run a 4150 carb on my combo for more street ability. Has anybody ran one of the 1050/4150 carbs against a smaller carb or a dominator? Do they make good power? I'm sure a dommy would make more top end hp but how much am I leaving on the table?
Re: Anybody run a 1050 4150?
[Re: viperblue72]
#2346853
08/01/17 07:42 PM
08/01/17 07:42 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Running huge carbs seems to be all the rage these days, so I won't even try and talk you out of it.
I'll just say that my one experience with one...... A qft-q1050......On a roller cammed, Indy headed 572....... was good. It made a few more hp than a Mighty Demon 850.
[Re: viperblue72]
#2346858
08/01/17 07:50 PM
08/01/17 07:50 PM
Thumperdart
State of confusion
Did a 1050 annular for a friend and his SB Chevy made 620 peak w/the annular and only 6 more peak w/Pettis's house 1050 dommy FWIW but I think it is a 3-circuit and a 2 would be better on this combo and most for that matter.........
[Re: viperblue72]
#2346871
08/01/17 08:24 PM
08/01/17 08:24 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I ran a 1050 AN on my 511 on a tm6. Pretty much mirrored the performance of my six pack using a 4412 center. I was able to dial the 1050 in to run really great at cruise and actually get better mileage than the six pack. Both setups ran 10.90's through mufflers at 4000# race weight. I really like my 1050.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: viperblue72]
#2346901
08/01/17 09:08 PM
08/01/17 09:08 PM
fast68plymouth
So. Burlington, Vt.
Fwiw, whenever I dynoed anything with the 4150/4500 adapter "upside down", the results were never great.
[Re: viperblue72]
#2346911
08/01/17 09:21 PM
08/01/17 09:21 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
I had a Prosystems 1000 with the metering blocks and squirters setup like a 1050, and it was awesome. And against a 1050 4500 Thumper carb, it was .08 slower in ET and almost 2mph slower overall. I would highly recommend the newer 1050 model he has and a Thumper tune or I can give you mine. Do not do annular 1050 4150.
[Re: viperblue72]
#2346956
08/01/17 10:36 PM
08/01/17 10:36 PM
viperblue72
I ordered the pro form 67305 which is down leg boosters 1050. I don't know what the actual cfm is. I hope it's close ootb like my last pro form carburetor.
[Re: Dragula]
#2346971
08/01/17 10:49 PM
08/01/17 10:49 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Do not do annular 1050 4150. Unless its a blowthrough.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: fast68plymouth]
#2346992
08/01/17 11:07 PM
08/01/17 11:07 PM
Thumperdart
State of confusion
Fwiw, whenever I dynoed anything with the 4150/4500 adapter "upside down", the results were never great. I'm with ya there although I never tested it personally, I've seen some guys say it works but my logic sez how could it.........These were NOS guys but still, a clean n/a signal and tune equates to a clean NOS pass all things being equal...........
#2347060
08/02/17 12:41 AM
08/02/17 12:41 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
I'll just say that my one experience with one...... A qft-q1050......On a roller cammed, Indy headed 572....... was good. It made a few more hp than a Mighty Demon 850. A few like 3 or 30?
[Re: viperblue72]
#2347103
08/02/17 02:11 AM
08/02/17 02:11 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
While I don't have experience with 4500 carbs, I recently went from a downleg 830 to an annular 1000 HP 4150. Right out of the box with only jetting and idle mixture adjustments, my 451 ran noticably crisper on the street with better throttle response and gained 2 tenths at the track.
It's notable that I changed the fuel delivery system at the same time, going from 5/16 to 1/2 line, and adding an auxiliary electric pump.
[Re: J_BODY]
#2347202
08/02/17 11:39 AM
08/02/17 11:39 AM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I run a 4150 style carb since I don't have intake gaskets for my 4500 intake.... and I don't want to ruin the ones that are presently on it. Have plenty of fun going 9.4's 9.5's.... CLASSIC Jay
[img] [/img]
[Re: 65Fury440]
#2347240
08/02/17 12:50 PM
08/02/17 12:50 PM
fast68plymouth
So. Burlington, Vt.
I'll just say that my one experience with one...... A qft-q1050......On a roller cammed, Indy headed 572....... was good. It made a few more hp than a Mighty Demon 850. A few like 3 or 30? It was about 5hp. .028" in Venturi diameter is only going to get you so much.
[Re: justinp61]
#2347319
08/02/17 02:51 PM
08/02/17 02:51 PM
BradH
I run a 4150 with a BLP BX4 main body on 434, BLP said it was 1050-1100 cfm. BLP has an "interesting" way of flow-testing their carburetors: "Carburetors are Dry Air Flow tested at 20.4” on a SuperFlow SF-1200 FlowCom flow bench using a 2” open hole spacer." Ever look at their flow ratings for significantly different carb sizes? Straight from their web site: - "750" 4150 w/ 1.405" Venturi 1.688" = 1030 CFM - " 850" 4150 w/ 1.590" Venturi 1.750" = 1060 CFM - " 950" 4150 w/ 1.405" Venturi 1.750" = 1060 CFM I suspect when you flow test carbs on a 2" open spacer that you're going to see less sensitivity to venturi & throttle size changes. If they were tested where the actual flow exiting the carburetor was isolated & measured (i.e., not dumped into a 2"-tall plenum first), the differences would be more apparent, and the max flow #s wouldn't be as high, either.
