Will a 12" wheel fit in a MINI-tubbed '68 Cuda #234438
02/24/09 12:19 AM
02/24/09 12:19 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Im ready to order wheels and really wanted a 12" wheel. The car is minitubbed with stock framerails. I had a '68 with 10" wheels and thought I remembered them fitting good. Anyone on here with a 12" and minitubbed A body? Pictures would be great. Thanks
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: DaKuda] #234439
02/24/09 01:34 AM
02/24/09 01:34 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Not really sure if you're gonna be able to do it. I've never looked up under a '67-'69 Cuda to see the area you'd be working with. I'm sure it'll fit with the correct measuring. Chris (B1Cuda) might have 12's on his Cuda. I can't remember, so I can't speak for him.
However, on my '72 Dart I had Alumastar wheels with double beadlocks, which increased my total wheel size to a little over 11" from the original 10". I ran the car with M/T 30x13.5 ET Street DOT's. They tucked decent for a minitub and stock framerail. If I ran a smaller tire I could've had the rear even lower. Had to trim the upper inner lip to let the car sit down on the tire a little without rubbing. Here's a pic.
Wes
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: EvilB1Dart] #234440
02/24/09 02:09 AM
02/24/09 02:09 AM
K
KOS Offline
KOS  Offline
K
it can be done but probably looking at custom wheels.if your still buying holeshot will make them for you.i think youll need btw 7-8"BS to work.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: KOS] #234441
02/24/09 02:20 AM
02/24/09 02:20 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'm putting 12" rims on my Duster, same wheelhouses as an early Cuda. I'd say the tire size is the bigger deal than the rim width. You should have about 15" of tub to work with.
Hard to get a wheel with enough backspace using a stock width rear.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: RobX4406] #234442
02/24/09 04:38 AM
02/24/09 04:38 AM
SW Missouri
W
willp Offline
willp  Offline
W
SW Missouri
I tried using a 12 drag lite 3 1/2 bs on my 68 Dart. Mini tubs, spring relocation, inner fender rolled, 1/2 wheel spacer, 44' dana, 12x29 Hoosier slick. If I remember correctly I have 15" of wheel well opening. The 12" wheel widened the center section of the tire and they would not fit. I use a 10" 3" bs weld star without a spacer now.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: DaKuda] #234443
02/24/09 07:43 AM
02/24/09 07:43 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have a 72 Duster with set of 12" wheels and 28x13.50 et streets under it and it is only mini tubbed and springs relocated! My buddy has a Barracuda and he also runs a 12" wheel and a 28x14.50 hoosier with no problem.
It takes a little measuring, but they fit.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: joshking440] #234444
02/24/09 07:43 AM
02/24/09 07:43 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: joshking440] #234445
02/24/09 07:46 AM
02/24/09 07:46 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I forgot to mention. Mine have 5" bs, but my rear end is chopped...
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: joshking440] #234446
02/24/09 07:52 AM
02/24/09 07:52 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
This is the only pic of the cuda I can find
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: joshking440] #234447
02/24/09 09:20 AM
02/24/09 09:20 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I don't see it. I have 9" rims. 2" out 7" in with 13.50 et streets and they are wall to wall. I don't see another 3" and dusters are have alot wider wheel wells than an older barracuda.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: DaKuda] #234448
02/24/09 09:35 AM
02/24/09 09:35 AM
ohio
prochamp Offline
prochamp  Offline
ohio
i have 12" rims with 71/2 backspace weld wheels.running phoenix 11.5x29.5 which are actual 12x30.0. stock width rearend.the main clearance issue is to make sure the inner tub is flush with the frame rail and not to get narrow at the top.the left side which is usually tighter is the one to look at.if you move your spring perches a little it helps alot with clearance.you don't have to center the rearend but move it a little definately helps otherwise you may have to use a spacer on that side.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: prochamp] #234449
02/24/09 09:46 AM
02/24/09 09:46 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I had a 69 Cuda that was mini tubbed using aftermarket tubs and springs moved into the frame rails.I ran a 12" wheel and a 12.2x 31.25 Firestone drag tire and it fit.Had to trim the wheel openings and eliminated the lips.
I used a 52" wide Dana.
Nautilus Racing-
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: DaKuda] #234450
02/24/09 11:44 AM
02/24/09 11:44 AM
Belle River
Q
QUIKFISH1850 Offline
Q
Belle River
Here's my cuda 13x31 rears there a little to big but thety fit I will step down to some 12.5 when these are done.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: QUIKFISH1850] #234451
02/24/09 01:44 PM
02/24/09 01:44 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have 10.5 width tyres, which actually measure just over 13" with the bulge of the tyre, if 12" wide tyres were fitted to my 10" rims, would the bulge width be the same or would i need 12" rims to keep it the same.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: deaks] #234452
02/24/09 02:18 PM
02/24/09 02:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My Duster runs 15x12s with 4.00" BS and a 13x31 tire; minitubbed, leaf springs in the rails, narrowed Dana. A bit tight, but no problems. Wheel openings are trimmed at the front & rear. Pics at http://topside.info on page 1 & 2.
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: topside] #234453
02/24/09 09:00 PM
02/24/09 09:00 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Thanks guys. The car is mini-tubbed but the rear is narrowed and Im running ladder bar coilovers. Would I be "safer" just running a 10"?
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: DaKuda] #234454
02/24/09 09:30 PM
02/24/09 09:30 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I run 12 inch wheel..it is a 4 inch backspace,but could go 4.5.I have run it with the 10 inch wheel also.with a 3.5 backspace.I actually like the looks of the car better with the 10inch..
My car is mini tubbed with ladder bars and coil overs.
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: EvilB1Dart] #234455
02/24/09 09:40 PM
02/24/09 09:40 PM
Central Missouri Fort Leonard...
mopar65 Online happy
mopar65  Online Happy
hi wes on your 72 dart was that with a stock width rear? also did you move the rear end back any?? I hope to get my car Mini-tubbed this summer and hope to get some 15x10 rims under it. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: mopar65] #234456
02/25/09 12:05 AM
02/25/09 12:05 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I had a 14" centerlines with 14.5 X 28 QTPS on my mini tubbed Dart Sport with stock length 8.75. The back space was 8".
Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda [Re: b1dartsport] #234457
02/25/09 12:40 AM
02/25/09 12:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
!2" wide rim with 6" bs with 11.5 29.5w's will not fit. Tire fits tight against the frame.
