Re: Will a 12" wheel fit in a MINI-tubbed '68 Cuda
[Re: joshking440]
#234444
02/24/09 07:43 AM
02/24/09 07:43 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: prochamp]
#234449
02/24/09 09:46 AM
02/24/09 09:46 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I had a 69 Cuda that was mini tubbed using aftermarket tubs and springs moved into the frame rails.I ran a 12" wheel and a 12.2x 31.25 Firestone drag tire and it fit.Had to trim the wheel openings and eliminated the lips. I used a 52" wide Dana.
[Re: QUIKFISH1850]
#234451
02/24/09 01:44 PM
02/24/09 01:44 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have 10.5 width tyres, which actually measure just over 13" with the bulge of the tyre, if 12" wide tyres were fitted to my 10" rims, would the bulge width be the same or would i need 12" rims to keep it the same. Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#234452
02/24/09 02:18 PM
02/24/09 02:18 PM
Posts: 20,762 A collage of whims
topside
A collage of whims
My Duster runs 15x12s with 4.00" BS and a 13x31 tire; minitubbed, leaf springs in the rails, narrowed Dana. A bit tight, but no problems. Wheel openings are trimmed at the front & rear. Pics at http://topside.info on page 1 & 2.
[Re: DaKuda]
#234454
02/24/09 09:30 PM
02/24/09 09:30 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I run 12 inch wheel..it is a 4 inch backspace,but could go 4.5.I have run it with the 10 inch wheel also.with a 3.5 backspace.I actually like the looks of the car better with the 10inch..
My car is mini tubbed with ladder bars and coil overs.
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: b1dartsport]
#234457
02/25/09 12:40 AM
02/25/09 12:40 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
!2" wide rim with 6" bs with 11.5 29.5w's will not fit. Tire fits tight against the frame.
