Re: 511 project
[Re: mopar dave]
#2343833
07/26/17 06:49 PM
07/26/17 06:49 PM
Posts: 4,691 Wichita
GY3
Wichita
Bend a piece of wire or coathanger to form the bends you need. Take it to the parts store and ask if you can look through their hose inventory. If I recall, my upper was a Ford Ranger part #.
Re: 511 project
[Re: GY3]
#2343983
07/26/17 11:24 PM
07/26/17 11:24 PM
dartman366
Mt. Vernon, Ohio
Bend a piece of wire or coathanger to form the bends you need. Take it to the parts store and ask if you can look through their hose inventory. If I recall, my upper was a Ford Ranger part #. thats the way I do it also.
Re: 511 project
[Re: mopar dave]
#2344092
07/27/17 07:41 AM
07/27/17 07:41 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I sectioned the chassis rails and fitted a 32" rad.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: 511 project
[Re: mopar dave]
#2344134
07/27/17 10:26 AM
07/27/17 10:26 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I think my crossflow on my 517 used a top hose from a 5.0 Lincoln Mark 7 if I remember right.
Might want to re-think the flex fan and go to electric pullers. Rigid/semi-flex fans are big HP killers. In fact Dulcich and Fryberger did an informative EngineMasters episode on it on youtube.
Re: 511 project
[Re: mopar dave]
#2344273
07/27/17 01:01 PM
07/27/17 01:01 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
yeah, the wires run under the headers. Gonna work on those today. You may have to make a tab that holds the wires against the engine and have the header bolt hold it.The good thing is you have aluminum heads with a sealed header bolt hole.
Re: 511 project
[Re: mopar dave]
#2344826
07/28/17 02:13 PM
07/28/17 02:13 PM
Clanton
northern,Ohio,USA
All went well with the plug wires under headers. Had to wire tie them back away from headers. Plugs are easy to change on dr side, but pass side is a bit difficult. Will removing the valve covers help you reach the plugs on the ps?This helps with getting to mine.
Re: 511 project
[Re: mopar dave]
#2345500
07/30/17 12:03 AM
07/30/17 12:03 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Egineered cooling products Radiator is in. Surprised how well the summit shroud fit radiator and fan. Think this will cool?
