Re: '01 Durango or Dakota 5.9 swap in place of a 4.7?
[Re: Hotwheelsjr]
#2343288
07/25/17 09:43 PM
07/25/17 09:43 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
I asked the same question when I was looking for a Durango a couple of years ago (bought a '00 w/ a 5.9). They were dirt-cheap and plentiful around here w/ a bad 4.7 so I figured it would be easy. The 5.9 has a different bellhousing pattern than the 4.7 (4.7 has same pattern as a Hemi). IIRC, the 5.9 would bolt up to the 4.7 mounts. BTW, a Hemi would be sweet but from what I can find, it is a LOT of work. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2343349
07/25/17 10:54 PM
07/25/17 10:54 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I asked the same question when I was looking for a Durango a couple of years ago (bought a '00 w/ a 5.9). They were dirt-cheap and plentiful around here w/ a bad 4.7 so I figured it would be easy. The 5.9 has a different bellhousing pattern than the 4.7 (4.7 has same pattern as a Hemi). IIRC, the 5.9 would bolt up to the 4.7 mounts. BTW, a Hemi would be sweet but from what I can find, it is a LOT of work. Tim The LA, magnum, 4.7 and 3rd Gen hemi all have the same bellhousing bolt pattern.
[Re: Hotwheelsjr]
#2343365
07/25/17 11:26 PM
07/25/17 11:26 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Way simpler to do a 5.7 and take the extra 100hp over the 360. Computer from a 5.7 truck or 5.7 Durango should set you straight. Jonesey, I see what you are getting at, but the 5.9 needs to talk to the RFE: I don't think it's doable. If it is: let me know how so I can boot my 46RE Turd out and put a 545RFE behind my 360 in an '01 Ram.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2343497
07/26/17 02:56 AM
07/26/17 02:56 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Way simpler to do a 5.7 and take the extra 100hp over the 360. Computer from a 5.7 truck or 5.7 Durango should set you straight. Jonesey, I see what you are getting at, but the 5.9 needs to talk to the RFE: I don't think it's doable. If it is: let me know how so I can boot my 46RE Turd out and put a 545RFE behind my 360 in an '01 Ram. What if you ran the separate TCM from a pre 2003 durango/Dakota 4.7? It'd definitely take some doing, but it might do the trick!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: Grizzly]
#2343666
07/26/17 01:50 PM
07/26/17 01:50 PM
Guitar Jones
Way simpler to do a 5.7 and take the extra 100hp over the 360. Computer from a 5.7 truck or 5.7 Durango should set you straight. Jonesey, I see what you are getting at, but the 5.9 needs to talk to the RFE: I don't think it's doable. If it is: let me know how so I can boot my 46RE Turd out and put a 545RFE behind my 360 in an '01 Ram. Interfacing the 5.9 to the later truck is the problem and not just with the trans. But the trans will bolt to the engine, that's about it though.
[Re: Hotwheelsjr]
#2343721
07/26/17 03:13 PM
07/26/17 03:13 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only feasable way is to find a wrecked 01 02 durango with the desired drivetrain. It will bolt up to the trans despite what others have said but it will not work it. The ECU controls the trans on the 5.9 while the 4.7 has a seperate TCU. Motor mounts are different, wiring harness, exhaust... many other things. If your donor computer or the recepiant rig have security you will need the BCM from the donor, that is one reason you can't use a dakota for a donor. If neither has a security system then you only have to modify the harness up front for the lighting, no idea why dodge thought the dak and dur needed different light wiring but they did so the harness is not a direct swap. A 2000 will not work as the complete under hood harness and the interior and BCM were changed with the updated interior in 2001. 2003 may or may not work depending on if you have a 3 plug or 4 plug ECU (you will need a 3 plug for an 01 and they seem to have done both through 2003).
The 5.7 may easier but you need to hook up a DBW throttle sensor and a 5.7 computer as the tooth count on your early 4.7 is wrrong for the 5.7 and you will need to swap the BCM to match whatever computer you use.
I curently own 6 durangos, have owned and worked on many, many more and have contemplated many swap posibilities but unless you keep the same engine family any swap is a PITB. Since nice 5.9 durangos are still cheap an plentifull I would sell the 4.7 rig put a few more bucks with it and just buy a 5.9 durango. If you decide you need a 5.7 durango at least find a blown up 2003 4.7 example so you can potentially leave the computers in it.
[Re: HotRodDave]
#2343864
07/26/17 07:48 PM
07/26/17 07:48 PM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
Thanks all for your input! The only feasable way is to find a wrecked 01 02 durango with the desired drivetrain. It will bolt up to the trans despite what others have said but it will not work it. The ECU controls the trans on the 5.9 while the 4.7 has a seperate TCU. Motor mounts are different, wiring harness, exhaust... many other things. If your donor computer or the recepiant rig have security you will need the BCM from the donor, that is one reason you can't use a dakota for a donor. If neither has a security system then you only have to modify the harness up front for the lighting, no idea why dodge thought the dak and dur needed different light wiring but they did so the harness is not a direct swap. A 2000 will not work as the complete under hood harness and the interior and BCM were changed with the updated interior in 2001. 2003 may or may not work depending on if you have a 3 plug or 4 plug ECU (you will need a 3 plug for an 01 and they seem to have done both through 2003).
I curently own 6 durangos, have owned and worked on many, many more and have contemplated many swap posibilities but unless you keep the same engine family any swap is a PITB. Since nice 5.9 durangos are still cheap an plentifull I would sell the 4.7 rig put a few more bucks with it and just buy a 5.9 durango. If you decide you need a 5.7 durango at least find a blown up 2003 4.7 example so you can potentially leave the computers in it. Dave -- I own 3 Durangos, myself...the 4.7 being the oddball out. My other two are a 99 4x4 5.9 and an 02 R/T. I was hoping to get away with swapping a 5.9 into the 4.7, but from the looks of it, I guess I'll be finding a 4.7 for it or selling it as is. Funny thing is, I paid less for the two 5.9 rigs together than I did for the 4.7 one. Thanks much for your input -- much appreciated. Makes my decision much easier.
[Re: Guitar Jones]
#2343959
07/26/17 10:43 PM
07/26/17 10:43 PM
I_bleed_MOPAR
Buford, GA
You are correct, sir. Went back and reread the info I was given and I missed the part where it would bolt up but would not work with that trans. Tim
