'01 Durango or Dakota 5.9 swap in place of a 4.7? #2342872
07/25/17 01:34 AM
07/25/17 01:34 AM
Surface of the Sun, AZ
Hotwheelsjr Offline OP
Anyone done a 5.9 swap into a 1st gen Durango that came original with a 4.7? What is required besides the PCM/harness? Are the motor mounts the same and will a 5.9 bolt up to a 45RE trans? I have a 01 4.7 Rango and pretty sure the motor is smoked. Would like to avoid another 4.7. Any help would be much appreciated!
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343258
07/25/17 08:47 PM
07/25/17 08:47 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Hi Mike. wave
Sorry don't have and info for you. Just wanted to say hey.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343288
07/25/17 09:43 PM
07/25/17 09:43 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I asked the same question when I was looking for a Durango a couple of years ago (bought a '00 w/ a 5.9). They were dirt-cheap and plentiful around here w/ a bad 4.7 so I figured it would be easy. blush
The 5.9 has a different bellhousing pattern than the 4.7 (4.7 has same pattern as a Hemi).
IIRC, the 5.9 would bolt up to the 4.7 mounts.
BTW, a Hemi would be sweet but from what I can find, it is a LOT of work. shocked
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: I_bleed_MOPAR] #2343349
07/25/17 10:54 PM
07/25/17 10:54 PM
Guitar Jones Online laugh2
Tim
The LA, magnum, 4.7 and 3rd Gen hemi all have the same bellhousing bolt pattern.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343363
07/25/17 11:25 PM
07/25/17 11:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I can tell you there is very little that interchanges between a 5.9 and a 5.7. If the stuff from a 4.7 is an easy swap to the 5.7, I'd be suspect that it would work on a 5.9.
I suspect that if you use the 5.9 stuff, it would bolt onto the chassis OK. Full size trucks are set up for the 4.7, the 5.9, and the 5.7 motors with the same chassis. Gene
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343365
07/25/17 11:26 PM
07/25/17 11:26 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Way simpler to do a 5.7 and take the extra 100hp over the 360.
Computer from a 5.7 truck or 5.7 Durango should set you straight.
Jonesey, I see what you are getting at, but the 5.9 needs to talk to the RFE: I don't think it's doable. If it is: let me know how so I can boot my 46RE Turd out and put a 545RFE behind my 360 in an '01 Ram. wink
Mo' Farts
Moderated by "tbagger".
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Grizzly] #2343497
07/26/17 02:56 AM
07/26/17 02:56 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
What if you ran the separate TCM from a pre 2003 durango/Dakota 4.7? It'd definitely take some doing, but it might do the trick!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Grizzly] #2343666
07/26/17 01:50 PM
07/26/17 01:50 PM
Interfacing the 5.9 to the later truck is the problem and not just with the trans.
But the trans will bolt to the engine, that's about it though.
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343690
07/26/17 02:13 PM
07/26/17 02:13 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I do not know them personally by any means but I do know of someone who works?/worked for Chrysler and had such a prototype combination. Of course such a combination never officially occurred because the 5.7 was in the pipeline.
The service manual for a 2002 Ram 1500 would be a good cheap starting point as those trucks had the option for the 5.9/46RE and the 4.7/45RFE as well as still using the old JTEC and EATX controller to run either combination. Figure out the interface of how/what the 4.7 talks to the RFE and see what the 5.9 needs to do, to accomplish the same.
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Hotwheelsjr] #2343721
07/26/17 03:13 PM
07/26/17 03:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The only feasable way is to find a wrecked 01 02 durango with the desired drivetrain. It will bolt up to the trans despite what others have said but it will not work it. The ECU controls the trans on the 5.9 while the 4.7 has a seperate TCU. Motor mounts are different, wiring harness, exhaust... many other things. If your donor computer or the recepiant rig have security you will need the BCM from the donor, that is one reason you can't use a dakota for a donor. If neither has a security system then you only have to modify the harness up front for the lighting, no idea why dodge thought the dak and dur needed different light wiring but they did so the harness is not a direct swap. A 2000 will not work as the complete under hood harness and the interior and BCM were changed with the updated interior in 2001. 2003 may or may not work depending on if you have a 3 plug or 4 plug ECU (you will need a 3 plug for an 01 and they seem to have done both through 2003).
The 5.7 may easier but you need to hook up a DBW throttle sensor and a 5.7 computer as the tooth count on your early 4.7 is wrrong for the 5.7 and you will need to swap the BCM to match whatever computer you use.
I curently own 6 durangos, have owned and worked on many, many more and have contemplated many swap posibilities but unless you keep the same engine family any swap is a PITB. Since nice 5.9 durangos are still cheap an plentifull I would sell the 4.7 rig put a few more bucks with it and just buy a 5.9 durango. If you decide you need a 5.7 durango at least find a blown up 2003 4.7 example so you can potentially leave the computers in it.
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: HotRodDave] #2343864
07/26/17 07:48 PM
07/26/17 07:48 PM
Thanks all for your input!
Dave -- I own 3 Durangos, myself...the 4.7 being the oddball out. My other two are a 99 4x4 5.9 and an 02 R/T. I was hoping to get away with swapping a 5.9 into the 4.7, but from the looks of it, I guess I'll be finding a 4.7 for it or selling it as is.
Funny thing is, I paid less for the two 5.9 rigs together than I did for the 4.7 one.
Thanks much for your input -- much appreciated. Makes my decision much easier.
Re: '01 Durango or Dakota 5.9 swap in place of a 4.7? [Re: Guitar Jones] #2343959
07/26/17 10:43 PM
07/26/17 10:43 PM
Buford, GA
Buford, GA
You are correct, sir. Went back and reread the info I was given and I missed the part where it would bolt up but would not work with that trans. blush
Tim
'71 Charger 383/727
