Bigger tires up front, more pronounced hunting on the road #2342475
07/24/17 03:49 PM
07/24/17 03:49 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
Went from 235/60r15s to 245/60r15s on the front and 245/60r15s to 255/60r15s on the back. Haven't adjusted the torsion bars yet, but I think the front end could be lowered down a little bit now.
The car has hunted a little bit forever, it has a FF stage 2 steering box, FF seemless HD tie rods, FF 1.06 torsion bars, moog problem solver bushings, new ball joints, pitman/idler arms, new LCA bushings, re-inforces LCAs, factory sway bar and poly bushings/endlinks.
The car feels like it has an inch of slop in the steering and will violently hunt back and forth
when it finds a new set of ruts. Is this bump steer? I have had no luck with local alignment/suspension shops. I thought maybe the return on the steering box needed some adjustment but now I am wondering if I just have some severe bump steer due to K frame issues.
I suppose I should adjust the ride height and have the alignment checked again. What should I be aiming for with the problem solver bushings and 15 inch radial tires(won't be going to larger tires for quite some time)
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2342671
07/24/17 08:37 PM
07/24/17 08:37 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The difference in height can't be much. I'd suspect the tires themselves to be the problem rather than the 1/4" increase in diameter.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2342687
07/24/17 08:53 PM
07/24/17 08:53 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Changing only tire diameter will effectively change your toe measurement up front.
Have you rechecked it? I am not sure how much a ~1/2" will change it, but it's worth validating.
Bump steer can be checked if you pull the torsion bar, put the tire/wheel back on and cycle the suspension. If the tire steers as the suspension cycles, you have an issue there.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2342827
07/24/17 11:55 PM
07/24/17 11:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What wheels do you have, or more to my point, did the offset change with change of wheel from OEM? Reason being, I've always suspected a change of wheel offset, would change tire "scrub, and might lead to wandering, this point I mention it because it is seldom discussed, why (?), because it has no merit, or whatever? Just throwing it out there.
"When the vehicle has been modified with offset wheels, larger tires, height adjustments and side to side camber differences, the scrub radius will be changed and the handling and stability of the vehicle will be affected." Wiki
https://en.wikipedia.org/wiki/Scrub_radius
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2343015
07/25/17 12:43 PM
07/25/17 12:43 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
Straightened the steering wheel when I got home last night and snugged some 2x4s next to the tires. I should have snapped some pictures, but it does appear that the tires are toed out a decent amount.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2343198
07/25/17 06:25 PM
07/25/17 06:25 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Tramlining. Often happens with wider tires. https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=47
Wheel offset effecting scrub can help or hurt tramming. Added caster can help over come it. Toe out will make it worse. Lower tire pressure can help some.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2343480
07/26/17 02:09 AM
07/26/17 02:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You only went up one side wider/taller tires. The car only rose a 1/4" ( radius of 1/2" diameter change). Your caster and camber will not change. The toe change is insignificant
How does this car's steering feel compared to the other vintage Mopars you've owned?
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2343518
07/26/17 07:22 AM
07/26/17 07:22 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
That could have been the problem the whole time. You can adjust your toe with the tie rods and your 2x4's. Try that and see if it changes anything. Mike
PS do you still have those headers from like 1999 I sent you? LOL
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Bigger tires up front, more pronounced hunting on the road [Re: HUSTLESTUFF] #2343732
07/26/17 03:44 PM
07/26/17 03:44 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
Holy smokes, yes, I kind of do! Was that off MoparChat or Moparts? I used the headers on the 318 but eventually put hooker super comps I snagged from the swap meet once I swapped to my 360. Installed the old headers on my grandpa's '4 Plymouth that had a diplomat front end in it. They fit surprisingly well. Mopar people are the best people! Was 15 when you sent me those headers!
I'm gonna lower the front end a smidge as it's riding fairly level right now and then re align it.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2345492
07/29/17 11:39 PM
07/29/17 11:39 PM
IN
ahy Offline
ahy  Offline
IN
Incorrect alignment can cause wandering... sounds like its time to have a look. Toe in promotes stability. Also positive caster. About 1/8" toe in and as much positive caster as you can get up to 5 degrees is bound to help.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2345501
07/30/17 12:05 AM
07/30/17 12:05 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
toe out will make it wander, i would fix that and see how it does...
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2346846
08/01/17 07:30 PM
08/01/17 07:30 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
For "pylon" autocrossing (where quick l-r-l-r-l-r responses are needed), a little toe-OUT is actually preferred as it helps quicken the maneuvers, but for street/highway/hi-speed track events a little toe-IN is preferred ... for stability at higher speeds.
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2351247
08/09/17 11:51 AM
08/09/17 11:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Toe out will wander as said.
Wider tires will wander too, but your change shouldn't be enough to change that.
I once had a set of 315 wide road race tires on the front of my Dakota. It wandered over every crown in the road, every rut in the asphalt. I did not like it and changed my wheel combo.
Now with 285 wide fronts, it does not wander
Adjust your toe and report back
**Photobucket sucks**
Re: Bigger tires up front, more pronounced hunting on the road [Re: FuryBoy] #2382812
10/06/17 02:01 AM
10/06/17 02:01 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Wander???? LOL!
