340 SIX PACK FOR STOCK ELIMINATOR #2340059
07/19/17 11:28 PM
07/19/17 11:28 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I am new to the Holley carbs always raced T Quads. I have been working on our restored V code Cuda have it running good now.
I am starting to work on the 340 for my D/S TA. I am going to put QFT billet metering plates on the end Carbs. I need to buy a selection of jets. I have 62's-68's for the center carb, I am thinking 80's-86's for the ends. I don't want to buy a whole bunch of jets that are gonna just sit in the box. I want to be in the ballpark. What do you guys think? Also is there a difference in jets from different companies?
Thanks, Rod
Real Men shift for themselves
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340090
07/20/17 12:19 AM
07/20/17 12:19 AM
Washington
madscientist Offline
Washington
Thanks, Rod
I like the BLP jets
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340099
07/20/17 12:33 AM
07/20/17 12:33 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Will the billet metering plates pass tech?
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340115
07/20/17 01:08 AM
07/20/17 01:08 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Login to classracer.com. Knowledge peeps there and even a specific stock/super stock tech section. Hint: Don Little is a 6-bbl guru! So is Steve Wann...
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340121
07/20/17 01:18 AM
07/20/17 01:18 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I have known Stevie Wann and Chicken Little for decades. I have raced Stock Eliminator on and off since 1973 all with Stick Shifted small blocks. Many time NHRA record holder. I was even in teardown when Cab got bounced for sand blasted heads.
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340135
07/20/17 01:55 AM
07/20/17 01:55 AM
That intake was glass beaded, it had the wrong carbs on it also shruggy The heads went through tech. fine up
Call Gene, he made his 340 fly 6 pack fly work
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340152
07/20/17 03:42 AM
07/20/17 03:42 AM
cudadoug Offline
cudadoug  Offline
You have known Don for years if you call him "Chicken" too!!
Ooooh, Cab you cheater...lol
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: Cab_Burge] #2340160
07/20/17 05:03 AM
07/20/17 05:03 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I know why Gene's car flew and that engine would not pass current tech.
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340234
07/20/17 11:42 AM
07/20/17 11:42 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
A small block E-body in D. That's brutal!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340247
07/20/17 11:56 AM
07/20/17 11:56 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am guessing you would be time and perhaps money ahead if you purchased some carbs from someone who has been there and done that. A lot of good knowledge here but you need to be on Classracer.com also.
Please keep us posted on your progress.
Good Luck!
Bill
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: MoparBilly] #2340354
07/20/17 02:32 PM
07/20/17 02:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I thought the hp factor had them in C.
Edit- I just looked it up...... "D" for a stick, "C" for an auto.
3480lbs with driver...... Nominal.
D stick can be as light as 3440.
C auto can be as light as 3360.
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340374
07/20/17 02:59 PM
07/20/17 02:59 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Just think Dwayne, you could NEVER get a D/S car to fly with a head as bad as a Pontiac has? Just think what the Mopar head could do?....lol
RIP Monte Smith
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340380
07/20/17 03:13 PM
07/20/17 03:13 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I am on Classracer. No one has ever been able to make the 340 six pack competitive with a stick very few have made them work with a slush box. Steve Hahn tried in the 70's Farmer is struggling with his McCoy has a F/S but it is slow.
The TA stick combo is a natural E/S car the AAR is a natural F/S. I want to go knock heads with the Z28's current record is 10.27 set in mineshaft air. A few years back my 72 Low compression ran 10.80's in F/S in not so good air.
Buying someone else's Carbs is not the answer. I have loaned people my Thermo Quad and tried theirs and we both slowed down. I expect the Holleys to be the same.
What I was looking for in my post was a general range of jets to get as a starting point. I have collected several carbs but few parts. The BLP jets look like a good way to go just looking for jet sizes.
Thanks, Rod
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340443
07/20/17 04:55 PM
07/20/17 04:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
You're right...... I don't know what I was thinking.
The AAR is 10.37 auto(319hp), 10.61 stick(312hp)........ E and F.
I think the challenge is to get the 6bbl to leave hard with a clutch and a small motor.
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340446
07/20/17 05:03 PM
07/20/17 05:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks, Rod
If you go w/BLP, use their conversion chart which compares holley jet #'s to get you close then tune from there. I'm not a 6-pack guy so no help there.......... thumbs
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340522
07/20/17 08:09 PM
07/20/17 08:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did the 6-pack have a better cam then the 4 barrel? I think the biggest advantage is the hood. What rpm did you get out of the 340, where did it fall off? Picking your brain for my combo. 70 Duster 340 avs. Why would the stick be rated more hp then the auto? Good luck
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: 1DGEMAN] #2340559
07/20/17 09:27 PM
07/20/17 09:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
When I used to run a 440 6-bbl (both my Challenger and Road Runner had 'em at one time) I had home-modified outboard plates to allow using "real" jets. Not sure what a Stocker 340 would want compared to a street/strip 440, but I'd say have 62-68 for the center carb and 76-84 for the outboards. Even that will likely leave you w/ some jets that never get wet... but it should cover you across a pretty wide range of conditions if you'll be traveling around to different tracks.
In addition to Holley jets, I have the COMP MaxJets because they have smaller increments between jet #s and IMO can be better fine-tuned. They're similar in many respects to the BLP jets, too. Both the MaxJets & BLP jets are sold by drilled hole size and use a cross-reference chart to match them as closely as possible to Holley jet #s.
Good luck! Me luv Challengers with T/A hoods! grin
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: BradH] #2340601
07/20/17 10:35 PM
07/20/17 10:35 PM
Syracuse,NY
Syracuse,NY
No help on the 6 pack, but BRad, thats looks great!
RIP Monte Smith
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: cudaman1969] #2340666
07/20/17 11:40 PM
07/20/17 11:40 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
The difference between the 4bbl and 6 Pack is just a tick more compression .004 thinner head gasket. NHRA allows the hood on both combos. The TA hood works. The AAR hood is just lighter.
I routinely ran my 72 340 to 7500 and a few times to 7800 in kill mode. The person to talk to about the AVS combination is Chuck Beach even though he runs an Auto (known him since the 70's when he had a stick in the same car).
Re: 340 SIX PACK FOR STOCK ELIMINATOR [Re: fast68plymouth] #2340678
07/20/17 11:47 PM
07/20/17 11:47 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Never a problem getting a stick car to leave. 7000rpm, Youngblood clutch, Cal Tracs and Hoosier tires.
