Page 1 of 3 1 2 3
511 Alive and well once again. #2339890
07/19/17 06:33 PM
07/19/17 06:33 PM
Alberta
Wookie316 Offline OP
Alberta
511 Dyno 837.6 HP
Back together and ready to go back in Barney. Here is the just of the build.
400 block with a Callie's 4.25 Dragonslayer
13.5-1 Diamond pistons
Indy EZ-1 heads flowing just under 370 @ .700
TTI 2 1/8 step headers
Indy single plane with 1050 Dom
Custom solid roller 268/276 with a hair over .700 lift
Peaked at 837.6 @ 6700 and carries nice till 7100
Because we never cut the cloverleaf out of the Manifold it does better with no spacer. I'm fine with that for hood clearance. Should be able to fit a 5" element in it this way.
It sounded real strong. Should work well.
Biggest issue is finding time and motivation to swap it out with the 440 with a drug problem.
Maybe next week.
I'd post a dyno sheet but Photobucket want $ from me.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 511 Alive and well once again. [Re: Wookie316] #2339955
07/19/17 08:07 PM
07/19/17 08:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Sounds like a nice build. Goodluck and have fun
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 511 Alive and well once again. [Re: Wookie316] #2339973
07/19/17 08:48 PM
07/19/17 08:48 PM
Alberta
Alberta
Thanks. Finding ambition to pull a perfectly good 440 out is my hurdle right now.
Re: 511 Alive and well once again. [Re: Wookie316] #2339990
07/19/17 09:21 PM
07/19/17 09:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sounds like a beast......... thumbs
Re: 511 Alive and well once again. [Re: Wookie316] #2339991
07/19/17 09:23 PM
07/19/17 09:23 PM
Those are good results up bow
Re: 511 Alive and well once again. [Re: Wookie316] #2340008
07/19/17 09:49 PM
07/19/17 09:49 PM
Alberta
Alberta
I knew it would run over 8. Just wasn't sure how much?
Re: 511 Alive and well once again. [Re: Wookie316] #2340045
07/19/17 10:50 PM
07/19/17 10:50 PM
Outside
thedriver Offline
thedriver  Offline
Outside
Well that answers my question. Saw the video first, came here to check 😂
1973 challenger
Dana. 4 speed. Low deck.
Re: 511 Alive and well once again. [Re: Wookie316] #2340085
07/20/17 12:10 AM
07/20/17 12:10 AM
Alberta
Alberta
Funny.
Re: 511 Alive and well once again. [Re: Wookie316] #2340089
07/20/17 12:18 AM
07/20/17 12:18 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Great stuff, so it is going in the SuperBee in your sig ? 9.50's ??
1963 Plymouth Max Wedge
1971 Barracuda
Re: 511 Alive and well once again. [Re: Wookie316] #2340124
07/20/17 01:29 AM
07/20/17 01:29 AM
Alberta
Alberta
Maybe with spray. NA at my weight won't run that low.
Re: 511 Alive and well once again. [Re: Wookie316] #2340455
07/20/17 05:19 PM
07/20/17 05:19 PM
an8sec70cuda Offline
Very nice! Put the plate on the big motor too!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 511 Alive and well once again. [Re: Wookie316] #2340467
07/20/17 05:41 PM
07/20/17 05:41 PM
Alberta
Alberta
Thanks. Hope to have some track #'s next Friday.
Re: 511 Alive and well once again. [Re: Wookie316] #2340778
07/21/17 02:17 AM
07/21/17 02:17 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Hey nice job Wookie !
That's just the combo I may be heading for....
I didn't know the EZ-1 could do so well...I called Indy today and they wanted to sell me the Big EZ for my 67 Barracuda....
I wonder how headers fit with 400 block and these heads in an A body
Dan
Re: 511 Alive and well once again. [Re: Wookie316] #2340874
07/21/17 11:34 AM
07/21/17 11:34 AM
Alberta
Alberta
I am spoiled in a B body with an Alterkation front end. Tons of room. I know anything in an A body can be a pain. Helped an bud put a 400 in his Duster last year. Inner fenders were removed and it was still a pain.
Re: 511 Alive and well once again. [Re: Wookie316] #2340899
07/21/17 12:07 PM
07/21/17 12:07 PM
tboomer Offline
tboomer  Offline
Cool build! Whats your car weigh? wave
Re: 511 Alive and well once again. [Re: Wedgeman] #2340932
07/21/17 01:06 PM
07/21/17 01:06 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The lo deck Maddogs fit my 67 barracuda nice. Needed a few dings but easy install. Took about 10 minutes on pass side. They are a slip tube design. Dr side takes a little longer with the steering box and colume to deal with.
Re: 511 Alive and well once again. [Re: Wookie316] #2340985
07/21/17 03:07 PM
07/21/17 03:07 PM
Alberta
Alberta
I am at the low low weight of 4100 at the line with full cell and tubby manning the wheel.
Re: 511 Alive and well once again. [Re: Wookie316] #2341050
07/21/17 05:27 PM
07/21/17 05:27 PM
shock
4100 kilo or pounds work whistling
Re: 511 Alive and well once again. [Re: Wookie316] #2341058
07/21/17 05:46 PM
07/21/17 05:46 PM
Alberta
Alberta
Pounds.
Re: 511 Alive and well once again. [Re: Wookie316] #2341060
07/21/17 05:47 PM
07/21/17 05:47 PM
Alberta
Alberta
If it was kilo it would be 9020 pounds. Yikes.
Page 1 of 3 1 2 3
