Re: Drive Shaft Requirements
[Re: JACK1440]
#2338341
07/17/17 01:33 PM
07/17/17 01:33 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I bent/twisted 2 stock shafts running mid 10s at 3700 lbs. You definitely need a good one at your level. I'm currently running a 3" dia. steel "thickwall" shaft made by my local HD truck shop. So far it's help up running 8.90s at 3900 lbs., but I honestly wouldn't be surprised if it failed on me. Everyone else at these speeds is running 3.5" dia. shafts.
[Re: JACK1440]
#2338490
07/17/17 05:38 PM
07/17/17 05:38 PM
Posts: 4,209 New York
polyspheric
New York
3.5" is much better than a simple comparison of diameters suggests. With the same wall thickness (I used 1/8" for this test) 3.5" is 62% stiffer than 3.0", and only weighs 17% more.
Boffin Emeritus
[Re: JACK1440]
#2338498
07/17/17 06:00 PM
07/17/17 06:00 PM
Posts: 4,457 Washington
madscientist
Washington
You are past due for a better than OE drive shaft.
[Re: JACK1440]
#2338537
07/17/17 07:04 PM
07/17/17 07:04 PM
Thumperdart
State of confusion
14+ years on the same 3 1/2" chrome moly shaft and just had new 1350 spicer u-joints installed and a re-balance..........over kill maybe..........
[Re: JACK1440]
#2338563
07/17/17 07:40 PM
07/17/17 07:40 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
How long is the shaft and how many RPM? My Cuda has the motor moved way back and it has a Powerglide, the drive shaft is small diameter and short. The former owner had a Blown alcohol B1 motor in it with 5:57 gears and 16x33x15 inch slicks Once I found out what ratio those gears actually where, I was told that it had either 5:13 or 5:38 in it, I swapped those gears out for a set of stock Dana Corp 4:56 gears I think it crosses the finish line in the 1/4 mile now right at 7000 RPM.
[Re: JACK1440]
#2339106
07/18/17 02:28 PM
07/18/17 02:28 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
I would agree with whats here for sure. IMO a 3" shaft will work fine but 3.5" aint gonna hurt. Also lots of material options out there. Most local shops can handle making something for your power level easy enough. If you want to aftermarket Mark Williams is the best IMO
