#2338337 - 07/17/17 11:23 AM Drive Shaft Requirements
JACK1440 Offline
Loc: MD
Question for you guys. At what point is a factory drive shaft not strong enough. We found that the drive shaft in the cuda was bent due to the motor / tranny grenading. So... we took a new shaft the shop to have it shortened and the shop told us we needed to go aftermarket. The car is 3300 and should run mid 9s. 727 Auto with a dana 60 rear. What do you think?
#2338341 - 07/17/17 11:33 AM Re: Drive Shaft Requirements [Re: JACK1440]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
I bent/twisted 2 stock shafts running mid 10s at 3700 lbs. You definitely need a good one at your level. I'm currently running a 3" dia. steel "thickwall" shaft made by my local HD truck shop. So far it's help up running 8.90s at 3900 lbs., but I honestly wouldn't be surprised if it failed on me. Everyone else at these speeds is running 3.5" dia. shafts.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2338490 - 07/17/17 03:38 PM Re: Drive Shaft Requirements [Re: JACK1440]
polyspheric Offline
Loc: New York
3.5" is much better than a simple comparison of diameters suggests.
With the same wall thickness (I used 1/8" for this test) 3.5" is 62% stiffer than 3.0", and only weighs 17% more.
Boffin Emeritus
#2338495 - 07/17/17 03:48 PM Re: Drive Shaft Requirements [Re: JACK1440]
JACK1440 Offline
Loc: MD
Wow... big difference in just an 1/8" on strength
#2338498 - 07/17/17 04:00 PM Re: Drive Shaft Requirements [Re: JACK1440]
madscientist Offline
Loc: Washington
You are past due for a better than OE drive shaft.
#2338525 - 07/17/17 04:44 PM Re: Drive Shaft Requirements [Re: JACK1440]
JACK1440 Offline
Loc: MD
That seems to be the general feeling. Looks like it's time for an upgrade....
#2338537 - 07/17/17 05:04 PM Re: Drive Shaft Requirements [Re: JACK1440]
Thumperdart Offline
Loc: State of confusion
14+ years on the same 3 1/2" chrome moly shaft and just had new 1350 spicer u-joints installed and a re-balance..........over kill maybe.......... thumbs
Edited by Thumperdart (07/17/17 05:04 PM)
72 Dart 470 n/a BB stroker street car `THUMPER`.....Check me out on FB for stories, videos and lots of carb pics..........760-900-3895........
#2338563 - 07/17/17 05:40 PM Re: Drive Shaft Requirements [Re: JACK1440]
Loc: Bend,OR USA
How long is the shaft and how many RPM?
My Cuda has the motor moved way back and it has a Powerglide, the drive shaft is small diameter and short. The former owner had a Blown alcohol B1 motor in it with 5:57 gears and 16x33x15 inch slicks shock
Once I found out what ratio those gears actually where, I was told that it had either 5:13 or 5:38 in it, I swapped those gears out for a set of stock Dana Corp 4:56 gears work
I think it crosses the finish line in the 1/4 mile now right at 7000 RPM.
#2338669 - 07/17/17 08:24 PM Re: Drive Shaft Requirements [Re: JACK1440]
polyspheric Offline
Loc: New York
Mark Williams has an excellent calculator for D/S size vs. speed here: http://www.markwilliams.com/driveshafttech.aspx
Boffin Emeritus
#2339098 - 07/18/17 12:15 PM Re: Drive Shaft Requirements [Re: JACK1440]
JACK1440 Offline
Loc: MD
Hey Cab, the drive shaft is 45" long and I figure the new motor will 6500 - 6800. The old motor turned 7200. The dana is a 4:88 gear
The Mark Williams graph is definitely handy.
I ended up contact the shop and am going with the heavier shaft with heavier yoke also
#2339106 - 07/18/17 12:28 PM Re: Drive Shaft Requirements [Re: JACK1440]
Al_Alguire Offline
Loc: Rockville MD & Las Vegas
I would agree with whats here for sure. IMO a 3" shaft will work fine but 3.5" aint gonna hurt. Also lots of material options out there. Most local shops can handle making something for your power level easy enough. If you want to aftermarket Mark Williams is the best IMO
#2339133 - 07/18/17 01:18 PM Re: Drive Shaft Requirements [Re: JACK1440]
Loc: Bend,OR USA
Do the math on the drive shaft RPM by figuring in the converter slip and then go from there. Add room for more RPM in the future up
#2339267 - 07/18/17 04:47 PM Re: Drive Shaft Requirements [Re: JACK1440]
JACK1440 Offline
Loc: MD
thanks for the advice guys
25,338 Registered Members
190,094 Topics
Slider brake pad question
by BDW
06/17/18 05:48 PM
69 A-Body 8.75 Rear Axle Shaft Spline Question
by vinnyd76
06/17/18 05:29 PM
What is this? Guy says 56 Chrysler 300?
by RUMBLON
06/17/18 05:01 PM
A couple of cool pictures from this weekends race
by pittsburghracer
06/17/18 04:58 PM
