Re: Stock trans limit?
[Re: Shatar4]
#2337814
07/16/17 03:12 PM
07/16/17 03:12 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
My "spare" 727 for my old Mirada running a RB 498 was nothing special. Reverse manual valve body. Foot braked it into the 10's. I had enough parts to throw it together as a backup plan. Ended up selling it after getting rid of the car. So I'm saying "yes" it's capable. now... would I run it with a stock front drum. NOPE! Are 727's "bulletproof"? NOPE! I currently have a 727 in the duster behind our small block. it's been out of the car 4 times in the last two years with odd and not so odd breakage. Most recent I broke the lugs on the pump gear. Hoping it will last now with aftermarket large lug gear, but I'm piecing together a 904 because I like torture ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: Shatar4]
#2337858
07/16/17 04:44 PM
07/16/17 04:44 PM
Posts: 4,213 New York
polyspheric
New York
Any foreign material in the filter?
Boffin Emeritus
[Re: Shatar4]
#2337927
07/16/17 07:23 PM
07/16/17 07:23 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
It sounds like it, the shifter or valve body selector, is not in each gear properly Take the pan back off and put the shifter in neutral and then remove the shifter selector from the arm on the valve body and watch the manual valve to see if it moves when you lift the shifter cable clevis or shifter bracket off the selector arm, if it moves you need to adjust the shift linkage so it doesn't move when removed in neutral, first, second and high gear ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Let us know what you find out ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) How good is your converter? What brand and foot and flash stall rating RPM? Good look on this ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Shatar4]
#2337947
07/16/17 07:54 PM
07/16/17 07:54 PM
Posts: 25,994 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Hit the gas motor Rome (sic) go up and then it just slams into gear Rear clutch problem....delayed engagement due to leakage. (rings/seals)
[Re: John_Kunkel]
#2337968
07/16/17 08:30 PM
07/16/17 08:30 PM
Posts: 4,704 Wichita
GY3
Wichita
I use a relatively stock one behind my 505.
I rebuilt it using better clutches, removed the governor, used a FWD pattern mvb and put the amount of springs in the front drum that Turbo action recommended. Other than that, it is pretty much stock.
It gets regular beatings on the track and street but I never do a 1st gear burnout, either!
Make sure you use a bronze thrust washer as most kits come with the fiber one and mine likes to eat those!
[Re: Shatar4]
#2338082
07/16/17 11:14 PM
07/16/17 11:14 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am not running a big motor like you have but I have been running a pretty much stock 727 with a manual valve body behind my small block that makes well over 600 hp. I have been running it for 5 years with no issues.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: John_Kunkel]
#2338089
07/16/17 11:27 PM
07/16/17 11:27 PM
Posts: 35 IN
formerratman
IN
Hit the gas motor Rome (sic) go up and then it just slams into gear Rear clutch problem....delayed engagement due to leakage. (rings/seals) ^ This.
[Re: Shatar4]
#2338251
07/17/17 11:05 AM
07/17/17 11:05 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I ran a pretty much stock 727 for about 2 years in my cuda running mid 9s at 3800 lbs. It had a manual valve body, deep pan, and a bolt in sprag...that's it. Then the drum exploded and disintegrated the transmission.
[Re: 383man]
#2338718
07/17/17 11:27 PM
07/17/17 11:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your builder messed up when he built the trans.. as John said the issue will most likely be a ring or a seal is bad.. a pressure test should show it.. I run a totally stock tran in my race car with a trans brake.. been in there about 10 years with 2 refreshens .. a light car is easy on parts ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: GY3]
#2338750
07/17/17 11:59 PM
07/17/17 11:59 PM
Posts: 3,396 Pa
Hot 340
Pa
Make sure you use a bronze thrust washer as most kits come with the fiber one and mine likes to eat those! What does removing the governor do? (I am tranny stupid ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) )
