Re: Cooling woes race motor
[Re: Stelldo]
#2333556
07/08/17 12:20 PM
07/08/17 12:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran a Omni/Horizon radiator in my SB for a number of years.. was OK but heated up on the return road.. on yours the biggest factor is the small fittings going to and from the block.. you can change the to copper so they are smoother on the ID
[Re: J_BODY]
#2334542
07/10/17 08:21 AM
07/10/17 08:21 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Pics of cooling system. I have ran this system since 2004. Friday night at the track , I had to change the remote water pump. It started getting noisy. I did have another Shogun Z pump in my trailer . Works Good again...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Stelldo]
#2335532
07/11/17 09:47 PM
07/11/17 09:47 PM
Posts: 23,273 Here
jcc
Here
Note, the Dual pass is not a plus for cooling in your application, and if possible, you may want to reconsider, ie, for one, it doubles the radiator water flow restriction vs a single pass, almost like taking two steps forward, and one backwards, IMO
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
