Hood scoop question #2333759
07/08/17 07:20 PM
07/08/17 07:20 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I am running a snorkel top on my tunnel ram. Car should run mid to low 8's. The opening is 2" x 13". I put 1" dams half way around the front of each carb. Should I be adding relief holes on the backside of the scoop? I have seen this done on street cars, but never on all out drag cars.
Re: Hood scoop question [Re: sgcuda] #2333782
07/08/17 08:25 PM
07/08/17 08:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I did the damn thing before but went back to open and cant say if it helped or not cos I lifted.........I'm not sold on that lid you run though and feel it's too close to the bowl vents but, maybe not just have to test and see........... beer
Re: Hood scoop question [Re: Thumperdart] #2333789
07/08/17 09:00 PM
07/08/17 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Test it first without before changing it...
its easier to add the holes later
wave
Re: Hood scoop question [Re: sgcuda] #2333794
07/08/17 09:12 PM
07/08/17 09:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As MrP said run it first as is. I also agree with Dominic and that is REALLY close to the vents. Especially if you have long vent tubes like Braswell, CFM run
Re: Hood scoop question [Re: sgcuda] #2333803
07/08/17 09:24 PM
07/08/17 09:24 PM
sgcuda Offline OP
sgcuda  Offline OP
The vents are only halfway up the scoop opening. 1" clearance to the top of the scoop.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334001
07/09/17 11:35 AM
07/09/17 11:35 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
I can't answer your question, but I like your car. Looks good
Re: Hood scoop question [Re: sgcuda] #2334023
07/09/17 12:05 PM
07/09/17 12:05 PM
sgcuda Offline OP
sgcuda  Offline OP
killermopar. Thanks. Between the heat and the storms coming through lately, plus the new job, it is hard to make time to work on her. I need to finish mounting the nose so that I can send her out for paint.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334044
07/09/17 12:52 PM
07/09/17 12:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On your scoop did you buy it new.. did you
add the holes
wave
Re: Hood scoop question [Re: sgcuda] #2334061
07/09/17 01:32 PM
07/09/17 01:32 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
my thinking would be with the amount of money you spent to run mid-to-low 8s... the hood scoop is not the place you want to skip out on.. the scoop that Close to the top of the carburetor will cause havoc on the vent tubes and boosters.. especially at the mph you're looking at... my two cents
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Hood scoop question [Re: sgcuda] #2334082
07/09/17 01:55 PM
07/09/17 01:55 PM
sgcuda Offline OP
sgcuda  Offline OP
I bought the scoop new, 30 years ago. No holes in the back of it yet. No choice on scoop design, due to class restrictions.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334092
07/09/17 02:10 PM
07/09/17 02:10 PM
sgcuda Offline OP
sgcuda  Offline OP
The scoop is 2 x 13 bot the roof is 2 1/2" above the carb. Is there a minimum distance that has been determined to work best? I can add spacers to the carb to raise it if needed, but I also need to be able to see the tree from the left lane.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334099
07/09/17 02:14 PM
07/09/17 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Run it, then make bowl vent tubes connecting the two with holes drilled in the tubes connected w/spark plug boots..........Confusing....... laugh2
Re: Hood scoop question [Re: Thumperdart] #2334108
07/09/17 02:27 PM
07/09/17 02:27 PM
sgcuda Offline OP
sgcuda  Offline OP
Not at all. I've seen that done before. Was going to just bend up a brass tube across the original vent tubes and put holes across the top side. Cleaner looking than the plug boot trick.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334118
07/09/17 02:40 PM
07/09/17 02:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what class is this for... look for a gray area in the rule
Re: Hood scoop question [Re: sgcuda] #2334127
07/09/17 02:47 PM
07/09/17 02:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: Hood scoop question [Re: sgcuda] #2334150
07/09/17 03:30 PM
07/09/17 03:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just put the boots on it for now.. your
just testing.. then once your done you
can make it pretty
wave
Re: Hood scoop question [Re: sgcuda] #2334166
07/09/17 04:10 PM
07/09/17 04:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What do the rules allow and not allow? If it has to be attached to the carbs/engine there are better choices. Go to Harwood's site and look at "dragster scoops" for some ideas.
Re: Hood scoop question [Re: sgcuda] #2334201
07/09/17 04:57 PM
07/09/17 04:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The interior cross-section area before the 1st carb should be much larger than the entry. This converts the forward air speed into positive pressure above the carbs.
Interior volume: big.
Height above the vent: 1 air-horn distance.
Boffin Emeritus
Re: Hood scoop question [Re: sgcuda] #2334257
07/09/17 06:41 PM
07/09/17 06:41 PM
sgcuda Offline OP
sgcuda  Offline OP
CMcAllister: Must be era correct. Snorkle scoops are the only ones that were used in the 70's. It was my idea to put the snorkel on the carbs without a base.
polysheric: No air horns on carbs. The top of the scoop is 2 1/2" above the carb, 1" above the top of the bowl vent. I wonder if I can get away with a modified top of the scoop (tent top) like Sox and Martin did on the Challengers.
[image][/image]
Re: Hood scoop question [Re: sgcuda] #2334355
07/09/17 10:11 PM
07/09/17 10:11 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
What about one of the plexiglass scoops that are popular now?
http://innovativeracecraftfl.com/shop/dual-carb-scoop-clear/
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
