Re: Hood scoop question
[Re: sgcuda]
#2333794
07/08/17 09:12 PM
07/08/17 09:12 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
As MrP said run it first as is. I also agree with Dominic and that is REALLY close to the vents. Especially if you have long vent tubes like Braswell, CFM run
[Re: sgcuda]
#2334023
07/09/17 12:05 PM
07/09/17 12:05 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
killermopar. Thanks. Between the heat and the storms coming through lately, plus the new job, it is hard to make time to work on her. I need to finish mounting the nose so that I can send her out for paint.
[image][/image]
[Re: sgcuda]
#2334061
07/09/17 01:32 PM
07/09/17 01:32 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I am running a snorkel top on my tunnel ram. Car should run mid to low 8's. The opening is 2" x 13". I put 1" dams half way around the front of each carb. Should I be adding relief holes on the backside of the scoop? I have seen this done on street cars, but never on all out drag cars. my thinking would be with the amount of money you spent to run mid-to-low 8s... the hood scoop is not the place you want to skip out on.. the scoop that Close to the top of the carburetor will cause havoc on the vent tubes and boosters.. especially at the mph you're looking at... my two cents
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: sgcuda]
#2334092
07/09/17 02:10 PM
07/09/17 02:10 PM
sgcuda
The scoop is 2 x 13 bot the roof is 2 1/2" above the carb. Is there a minimum distance that has been determined to work best? I can add spacers to the carb to raise it if needed, but I also need to be able to see the tree from the left lane.
[image][/image]
[Re: Thumperdart]
#2334108
07/09/17 02:27 PM
07/09/17 02:27 PM
sgcuda
Run it, then make bowl vent tubes connecting the two with holes drilled in the tubes connected w/spark plug boots..........Confusing....... Not at all. I've seen that done before. Was going to just bend up a brass tube across the original vent tubes and put holes across the top side. Cleaner looking than the plug boot trick.
[image][/image]
[Re: sgcuda]
#2334118
07/09/17 02:40 PM
07/09/17 02:40 PM
WHITEDART
bean town ....Ca
I bought the scoop new, 30 years ago. No holes in the back of it yet. No choice on scoop design, due to class restrictions. what class is this for... look for a gray area in the rule
[Re: sgcuda]
#2334150
07/09/17 03:30 PM
07/09/17 03:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just put the boots on it for now.. your just testing.. then once your done you can make it pretty
[Re: sgcuda]
#2334166
07/09/17 04:10 PM
07/09/17 04:10 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What do the rules allow and not allow? If it has to be attached to the carbs/engine there are better choices. Go to Harwood's site and look at "dragster scoops" for some ideas.
[Re: sgcuda]
#2334201
07/09/17 04:57 PM
07/09/17 04:57 PM
Posts: 4,206 New York
polyspheric
New York
The interior cross-section area before the 1st carb should be much larger than the entry. This converts the forward air speed into positive pressure above the carbs. Interior volume: big. Height above the vent: 1 air-horn distance.
Boffin Emeritus
[Re: sgcuda]
#2334257
07/09/17 06:41 PM
07/09/17 06:41 PM
sgcuda
CMcAllister: Must be era correct. Snorkle scoops are the only ones that were used in the 70's. It was my idea to put the snorkel on the carbs without a base. polysheric: No air horns on carbs. The top of the scoop is 2 1/2" above the carb, 1" above the top of the bowl vent. I wonder if I can get away with a modified top of the scoop (tent top) like Sox and Martin did on the Challengers.
[image][/image]
[Re: sgcuda]
#2334355
07/09/17 10:11 PM
07/09/17 10:11 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
What about one of the plexiglass scoops that are popular now? http://innovativeracecraftfl.com/shop/dual-carb-scoop-clear/
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
