CNP system #2333725
07/08/17 06:07 PM
07/08/17 06:07 PM
Sonora CA
Mopar_Rich Offline OP
Sonora CA
Andy and I have brought CNP (Coil-Near-Plug) to the Mopar crowd. This will fit any B or RB Mopar, will not interfere with any head and is plug-and-play with either the Holley HP or Dominator EFI systems. Crank is 36-1 and cam is one pulse per rev. Both Crank and Cam sensors are Hall-Effect and stable at any RPM. Andy's product quality comes through again.
Re: CNP system [Re: Mopar_Rich] #2333885
07/08/17 11:42 PM
07/08/17 11:42 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
That should be a cool deal for those who can't build there own.
The only Carbs I care about are under the hood!
Re: CNP system [Re: Azzkikrcuda] #2333926
07/09/17 01:50 AM
07/09/17 01:50 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I want one! Price?
Re: CNP system [Re: Mopar_Rich] #2333930
07/09/17 02:21 AM
07/09/17 02:21 AM
AndyF Online content
AndyF  Online Content
Looks good Rich, nice job getting the harness built.
I have the SB cam sync drawn up and will build some when I do the next batch of parts.
Re: CNP system [Re: Mopar_Rich] #2333963
07/09/17 09:47 AM
07/09/17 09:47 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks Nice!
68 Barracuda Formula S 340
Re: CNP system [Re: Bad340fish] #2333973
07/09/17 10:38 AM
07/09/17 10:38 AM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
Very nice and clean looking. I bought my dual sync distributor 6 months too soon! Oh Well.
Re: CNP system [Re: Jeremiah] #2334091
07/09/17 02:09 PM
07/09/17 02:09 PM
Sonora CA
Sonora CA
Originally Posted By Jeremiah
I want one! Price?
Prices are on my web site under Products/CNP Products
Rich
fastmanefi.com
Re: CNP system [Re: Mopar_Rich] #2334098
07/09/17 02:13 PM
07/09/17 02:13 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
For us Luddites, can you explain something? If the crank sensor tells the system where the motor is, why does it need a cam sensor?
Does this use 8 coils, with a wire to each plug? COuld it be used with coil on plug in a 426 Hemi?
THanks, Joel
Re: CNP system [Re: Mopar_Rich] #2334114
07/09/17 02:34 PM
07/09/17 02:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Someday I hope to have EFI...........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: CNP system [Re: Hemi_Joel] #2334129
07/09/17 02:50 PM
07/09/17 02:50 PM
Sonora CA
Sonora CA
THanks, Joel
It works great on a 426 HEMI since the HEMI is an RB block.
Yes, 8 coils with a coil to each plug.
Below is from my web site. There will be a quiz afterwards!!!
Why go CNP?
Coil-Near-Plug is used on almost all modern engines. OEMs do this to virtually eliminate ignition noise from modern heavily computer populated cars. It eliminates the ignition coil and distributor, and it also allows for individual cylinder timing adjustments. Spark energy increases because the coils have plenty of time for dwell saturation regardless of RPM. And EFI data logging is so robust that a separate data logger is not needed.
A Quick CNP Tutorial
The ECU must know when to fire each coil. There are two ways to do this:
Waste spark with missing tooth trigger wheel:
When the ECU sees the gap on a 36X or 58X trigger wheel it knows that the engine is coming up to TDC for either cylinder number 1 OR number 6 (assuming a 18436572 firing order). It cannot tell which coil to fire since both are coming up to TDC, but only one is starting the power stroke while the other is starting the intake stroke. So the ECU will fire BOTH #1 and #6 coils thereby wasting a spark. This is an acceptable technique that can be used if there is no cam sensor, however the trigger wheel must be a missing tooth style, and individual cylinder timing control is not possible.
Sequential spark using a CAM sensor:
A cam sensor generates one pulse, or edge, per camshaft revolution. This allows the ECU to be in sync with the engine’s cycle and fire only one coil, thereby not wasting a spark, and the ECU can also control individual cylinder timing.
Since the cam sensor synchronizes the ECU to the engine cycle the crank trigger wheel does not have to be a missing tooth style. A typical configuration would be a trigger wheel with four magnets and the pickup. However, you can use the 36X or 58X style wheels with a cam sensor as well. In fact, the missing tooth wheel is preferred because the timing is more accurate during rapid changes in engine RPM. Using a CAM sensor is better than the waste spark method.
Re: CNP system [Re: Mopar_Rich] #2334139
07/09/17 03:04 PM
07/09/17 03:04 PM
Here is the most recent picture of the coils mounted on the valve cover. I had the brackets anodized black so they match the coils. Custom wires from Firecore are the finishing touch.
With the coils mounted this way the wires tuck in nicely between the header tubes. I should have this setup back on the dyno in a few weeks. It will be interesting to see how it works with the individual cylinder control.
Re: CNP system [Re: Mopar_Rich] #2334210
07/09/17 05:13 PM
07/09/17 05:13 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I see you have the ign1/Holley coils. I just put a set on a guys car to replace a set of "heat sink" GM coils. The car now has a quiet, yet noticeable high frequency "buzz" sound from the coils with the key on/ engine off. Do they all do this, or do I have something going on?
Re: CNP system [Re: Mopar_Rich] #2334266
07/09/17 07:26 PM
07/09/17 07:26 PM
Sonora CA
Sonora CA
These smart coils sometimes have a high frequency buzz because of their internal oscillator, but you don't hear it when the engine is running. I wouldn't worry about it.
Re: CNP system [Re: Mopar_Rich] #2334988
07/10/17 10:28 PM
07/10/17 10:28 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The CNP stuff is definitely the way to go anymore. I'm fortunate enough to get close up looks at the fastest PM, and radial cars in the world while they're being built. The mags are even going away in favor of CNP in PM turbo cars too.
Way to go Rich!
Re: CNP system [Re: Mopar_Rich] #2337025
07/14/17 07:10 PM
07/14/17 07:10 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Thanks for the trust with the ignition wires, both Andy and Rich!! Looks killer..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: CNP system [Re: Mopar_Rich] #2337026
07/14/17 07:12 PM
07/14/17 07:12 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Re: CNP system [Re: Mopar_Rich] #2338708
07/17/17 11:15 PM
07/17/17 11:15 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would love to put one on my 572 hemi, but until I finish the car, I have to hold off on modifying things....Rich, is it possible to put a dual sync without having a separate crank sensor, something like the jeep one? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: CNP system [Re: astjp2] #2338990
07/18/17 12:29 PM
07/18/17 12:29 PM
Sonora CA
Sonora CA
Yes. Holley offers their dual-sync dizzy with a cover instead of plug wire terminals. Then you have both Cam and Crank signals ready to go for CNP. Andy and I are working on a smaller engine position module that does the same thing but in a much smaller package.
Re: CNP system [Re: Mopar_Rich] #2339619
07/19/17 11:34 AM
07/19/17 11:34 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Does anyone make a cover (cap replacement) for the old Mopar steel/iron distributors? I have a small block tach drive distributor. I would like to go to CnP, keep the mechanical tach and not have to leave the empty distributor cap on the distributor.
Bill
Re: CNP system [Re: 340Cuda] #2339620
07/19/17 11:38 AM
07/19/17 11:38 AM
Sonora CA
Sonora CA
Bill
Not that I'm aware of, but I'm sure someone could make one.
