Multi Carb Synconizer #2333205
07/07/17 05:33 PM
07/07/17 05:33 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Does anybody know where I could find a uni sync that will fit four bbl carbs?
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333209
07/07/17 05:44 PM
07/07/17 05:44 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Dvorak Machine sells one. Their website's down though it seems.
The one they offer is just a regular uni sync attached to a cheap plastic carb cap
I made my own thats pretty nice with a beefy billet cap. Only took a few minutes to build with a hole saw and a few selft tapping screws.
Re: Multi Carb Synconizer [Re: Diplomat440] #2333240
07/07/17 06:47 PM
07/07/17 06:47 PM
Morristown Tn.
Morristown Tn.
Larry Sheppard has them also, but he wants $200 for one. That
s to F...... high.
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333244
07/07/17 06:57 PM
07/07/17 06:57 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I think i have about $40 in this. $25 for the uni sync and $15 for the cap.
Got the stuff from summit of jegs a few years back when i put the tunnel ram on my Diplomat.
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333248
07/07/17 07:05 PM
07/07/17 07:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
Edlbrock is who I bought mine form years ago, probably Summit and Jegs offers them now as already pointed out scope
I use to use mine on most six pack, cross rams and tunnel ram motors I tuned until I learned to listen carefully to motor at the idle speed when adjusting the idle mixture screws and idle speed screws work scope
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333308
07/07/17 09:50 PM
07/07/17 09:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Ah a wonderful tool and brings backs great memory's racing methanol injected dragsters.
Used a Uni syn to tune the idle on these kinsler magnesium
stack injectors. After a while I could hear when it was right and used the uni syn to check my work. The engine cackled just perfect at idle and you could hear when it was right. Then when that happens the plugs are all heated more evenly at launch so the engine makes immediate horsepower and revs faster.
This is my second injected dragster, 632" donovan big chief pontiac 1200hp without N2O in 1993.
451" hemi.
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333324
07/07/17 10:19 PM
07/07/17 10:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
sweet
Don't be the exception.
Re: Multi Carb Synconizer [Re: Supercuda] #2333356
07/07/17 11:36 PM
07/07/17 11:36 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sorry to hi jack, the Uni Syn is a great tool and I can see needing it for your dual quad hemi. Same deal as I was talking about with the plugs on your motor.
Someone I am sure makes a 4 barrel adapter but I don't know where to find one right off hand.
I raced this 2.9 crower stack injected 572 BB chevy with dart 360 heads dragster. It had kinsler installed split shafts in it so I could tune the manifold at idle with the Uni Syn. 1000 hp motor.
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333520
07/08/17 11:19 AM
07/08/17 11:19 AM
moparx Offline
moparx  Offline
Originally Posted By 71birdJ68
That
s to F...... high.
ahh.... "used cars" quote. laugh2 my second favorite movie of all time !
beer
Re: Multi Carb Synconizer [Re: moparx] #2333627
07/08/17 02:40 PM
07/08/17 02:40 PM
Morristown Tn.
Morristown Tn.
Yes, here at New Deal Used Cars, we blow the living S..t out of high prices.
Re: Multi Carb Synconizer [Re: 71birdJ68] #2333840
07/08/17 10:18 PM
07/08/17 10:18 PM
Ohio
lockjaw-express Offline
Ohio
Here is one I found on Moparts, built using PVC Fittings!
Mark
Re: Multi Carb Synconizer [Re: moparx] #2333842
07/08/17 10:24 PM
07/08/17 10:24 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Used cars, agreed at number 2, with Gumball Rally at number 1,,,both with some great one liners,,,,Original Vanishing Point and Steve McQueen's Le Mans fitting somewhere in my top 5 car movies. And cannot forget Bullett.
