Speedo cable adapter #233200
02/22/09 09:18 PM
02/22/09 09:18 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Does anyone make an adapter to use a 65 speedo cable with a 69 4 speed trans
Re: Speedo cable adapter [Re: gts1] #233201
02/22/09 09:44 PM
02/22/09 09:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can you change out the speedo gear holders? I don't know but it might be worth looking at.
Re: Speedo cable adapter [Re: gts1] #233202
02/22/09 10:47 PM
02/22/09 10:47 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
A '66-7 cable is exactly what you need. Will bolt right in
Re: Speedo cable adapter [Re: 446acuda] #233203
02/23/09 01:32 PM
02/23/09 01:32 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Re: Speedo cable adapter [Re: gts1] #233204
02/23/09 08:06 PM
02/23/09 08:06 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Isn't the 65 based on an entirely different gear in the trans.. the gear that drives the speedo pinion?
That means the 65 uses one style speedo pinion and the 66 up uses a different style. So if you find a cable that will work... would the speedometer work Correctly??
Am I understanding your question correctly?
Re: Speedo cable adapter [Re: Mr_fixit] #233205
02/23/09 09:48 PM
02/23/09 09:48 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Been through it a few times and speedometer works fine with on '65-older and '66 newer trans as long as you have the correct speedo gear of course.
Re: Speedo cable adapter [Re: 446acuda] #233206
02/23/09 11:00 PM
02/23/09 11:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The cable works as a straight link so it has to work correctly. It has nothing to do with the gear in the trans other than being turned by it. All the cable has to do is hook up right on both ends.
Re: Speedo cable adapter [Re: stumpy] #233207
02/24/09 04:16 PM
02/24/09 04:16 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Actually, every 65 speedo cable I personally have ever seen has the adaptor essentially molded onto the end of the cable itself. Never seen one with a removable cable housing. The 66 and up units I'm familiar with have all had the adaptor housing and cable as separate pieces. That unitized type cable construction is why us 65 guys have so much fun trying to find the correct gears.
OR... if he's suggesting to use the 66 cable to install a later, (post 65), trans into a 65 car - then I can readily believe that will work.
Mike
Re: Speedo cable adapter [Re: 1E2C] #233208
02/24/09 04:38 PM
02/24/09 04:38 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Okay, so after I answered I went back and re-read the original post again and the reply that a 66 vintage cable will work to hook the 65 speedometer to a 69 trans is correct. Sorry, I got sidetracked by my frustration finding correct gears for my 65 stuff. Anyhoo, I went and took a pic of the tranny end on a 65 and previous years tranny, it's tacked on here.
Mike
