Re: Power Steering - Police box?
[Re: urdustd]
#233103
02/22/09 08:34 PM
02/22/09 08:34 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I need to replace/rebuild the stock power steering box in my 74 Duster. I would like to get a "police firm feel" box for it as I personally think the stock units are way too light. I looked at the Firm Feel stuff, but was hoping the factory unit was still available. Any suggestions? And sorry I'm not going to manual as I drive the car....
Does anyone have any experience with the Firm Feel units?
Factory units are discontinued.
[Re: urdustd]
#233107
02/23/09 01:08 AM
02/23/09 01:08 AM
autoxcuda
So Cal
Thanks guys for the replies!
autoxcuda, what are you using on your Cuda?
70sixpkRT - how would you compare it to the factory box?
I'm using a Mopar Parts re-manufactured box I bought in 1993 for like $165. I think it's discontinued now. That was 50K miles ago.
I thought since it was re-manufactured it would have NEW interals, not just rebuilts ones. Can anyone varify that?
Now 50K miles later, I see the output shaft has side play when it's up on jackstands and I move the wheels back and forth. Those 50K or so miles were not easy ones though
The feel on my unit is nice. But I don't think it has the effort of a Police box. BUT there are a lot of things that effect feel and effort that don't have to do with the steering box. Mods to my car that would effect steering feel and effort:
*Smaller 15" La Carrra Steering wheel give less leaverage and take more effort to turn *3-5 degrees positve caster. Postive caster makes the car want to return to center and takes more driver effort to turn. *225/60/15 tires I ran 60 series Dunlop H speed rated tires. Smaller sidewall gives more responsive reaction to steering inputs. I've run 225/50/15 ZR and 245/50/15 ZR tires with event stiffer sidewalls and there are more responsive.
Now, I do have a Firm Feel Stage II rebuilt box in my 68 Dart Conv. That car has stock 16" steering wheel, 245/60/15 series tires, stock torsion bars, and it's a convertible (flex). Feels about the same as my Barracuda in regards to effort.
[Re: cuda70]
#233110
02/24/09 12:18 AM
02/24/09 12:18 AM
Posts: 660 River Falls, WI
urdustd
River Falls, WI
I got one from advance auto for 1989 Dodge Diplomat SE Police P/S Gear Box Product Number: NSP276515 . I think it was around $170.
Thanks cuda70
Rockauto.com and partsamerica.com both carried it, but it's a reman'd Cardone unit p/n 276515. I also found it on autopartsgiant.com for $115. Problem is they all have a $125 core charge...maybe they won't be able to tell the difference when I send back my old standard box, maybe.
[Re: urdustd]
#233111
02/24/09 12:50 AM
02/24/09 12:50 AM
replace/rebuild your unit.install a sway bar.[maybe rear axel too]money well spent.
[Re: Jwilli500]
#233113
02/24/09 02:44 AM
02/24/09 02:44 AM
autoxcuda
So Cal
OK Starting around 74 IIRC they went to a larger sector shaft coming out of the steering box. What pitman arm would you use in an earlier B or E Body that had a smaller shaft? I'm guessing the later B-Body (Cordoba etc) one?
They went large sector in 73. For large sector box in a 68-72 B-body use a 74 Challenger pitman.
