727 Sprag #2328247
06/28/17 08:31 PM
06/28/17 08:31 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
At what point is it necessary or recommended to install an "ultimate" or "super sprag" over 12 roller bolt in sprag?
Re: 727 Sprag [Re: justinp61] #2328285
06/28/17 09:55 PM
06/28/17 09:55 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
IMHO when your sprag is bad or showing lots off wear. If you have low band apply sprag importance drops quite a bit
Re: 727 Sprag [Re: justinp61] #2328326
06/28/17 10:56 PM
06/28/17 10:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran the stock 65 sprag for 200 passes with a non LBA apply valve body running high 1.2 low 1.3 60ft foot braking. When it was pulled it looked like new. I stepped up to the good one, still no issues at 425 passes. Dizusters turbo car killed the stock at less than 100 passes with a LBA valve body using a brake, high 1.3 low 1.4 60ft.
Doug
Re: 727 Sprag [Re: justinp61] #2328342
06/28/17 11:28 PM
06/28/17 11:28 PM
P
Porter67 Offline
Porter67  Offline
P
Not sure myself, but if you need a oem one, this is as cheap as it gets.
http://www.ebay.com/itm/NOS-Mopar-A727-A904-OVERRUN-CLUTCH-SPRING-ROLLER-KIT-REAR-SPRAG-KIT/152511409425?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Re: 727 Sprag [Re: justinp61] #2328344
06/28/17 11:36 PM
06/28/17 11:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're worried about safety, you money would be better spent by applying it to a billet front drum.
Re: 727 Sprag [Re: John_Kunkel] #2328352
06/28/17 11:50 PM
06/28/17 11:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
saved me from typing the same thing....
Re: 727 Sprag [Re: justinp61] #2328364
06/29/17 12:07 AM
06/29/17 12:07 AM
W. Kentucky
W. Kentucky
The trans already has a billet steel front drum and I have a nearly new bolt in sprag. I was just curious as to when a better one was needed.
Re: 727 Sprag [Re: justinp61] #2330761
07/03/17 04:36 PM
07/03/17 04:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When you decided to put in the current 12 bolt. Rarely does the outer race's press fail , its the 12 rollers that fail. Your current unit still can fail, it takes more to make a 16 roller fail.
Re: 727 Sprag [Re: JohnRR] #2330799
07/03/17 06:08 PM
07/03/17 06:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, here's a 16-element SuperSprag failure with the cam ring in place.
Re: 727 Sprag [Re: justinp61] #2330878
07/03/17 06:52 PM
07/03/17 06:52 PM
W. Kentucky
W. Kentucky
Thanks guys, I'll use the sprag I have.
Re: 727 Sprag [Re: John_Kunkel] #2331152
07/04/17 02:49 AM
07/04/17 02:49 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
What causes that?
I have lots of miles, strip passes and even a few u-joints that broke. I always pull apart the trans to check the sprag after a failure and never had an issue.
I do have a LBA forward pattern manual valvebody and always shift to second on the burnout.
'63 Dodge 330
11.19 @ 121 mph
Re: 727 Sprag [Re: John_Kunkel] #2332534
07/06/17 03:05 PM
07/06/17 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Something seriously wrong happened there , downshift into low at about 100mph with no LBA ???
Re: 727 Sprag [Re: JohnRR] #2332828
07/06/17 11:49 PM
07/06/17 11:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Saw one just like it in a 10.0 foot brake car that broke a ring gear.
Doug
Re: 727 Sprag [Re: John_Kunkel] #2333208
07/07/17 05:40 PM
07/07/17 05:40 PM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
That is my photo, its from my friends valiant. +900hp 1080nm big block. It broke the rear end (8 3/4) and after about 10passes it grenaded the sprag.
The case got a small crack but we didnt have spare one at the time, installed new super sprag and after around 25-35 passes it broke again. Picture attached.
It has aluminum drum and in both cases the springs were all over the place, retainer still in place. Drum had spinned very fast.
I fixed it again few weeks ago with new good case and new super sprag and few other items. Week ago it went 8.88s at 1/4 with zero problems so far, fingers crossed.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: 727 Sprag [Re: justinp61] #2333213
07/07/17 05:54 PM
07/07/17 05:54 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I did the Billet steel drum complete from CRT as well as the Ultimate sprag also from CRT.
Not because of power as much as the 3,950 weight.
Fairly heavy car on a radial slick that hit's high 1.5's in the sixty in the spring and fall.
Piece of mind.
If the sprag does fail I'm hoping to not wear the drum.
Do have a new Dana, 1350 yoke front and rear and a 3-1/2 driveshaft.
Re: 727 Sprag [Re: justinp61] #2333249
07/07/17 07:06 PM
07/07/17 07:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I put a better bolt in rear overrunning clutch (sprag) in my trans but still have the stock front drum. I dont race much as the past few years I only get to the track about once a year and put from 4 to 8 passes a year on it. I have never had a problem in any of my cars but I did put a trans blanket on my 63 about 4 years ago. Dont know how good a blanket really works but it helps give me a little piece of mind until I update the drum. I hope I never have to test the blanket. Ron
Re: 727 Sprag [Re: John_Kunkel] #2333295
07/07/17 08:47 PM
07/07/17 08:47 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
"The case got a small crack but we didnt have spare one at the time, installed new super sprag and after around 25-35 passes it broke again."
When the facts are revealed, the correct information is applicable.
