Re: 727 Sprag
[Re: justinp61]
#2328344
06/28/17 11:36 PM
06/28/17 11:36 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're worried about safety, you money would be better spent by applying it to a billet front drum.
Re: 727 Sprag
[Re: John_Kunkel]
#2328352
06/28/17 11:50 PM
06/28/17 11:50 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
saved me from typing the same thing....
Re: 727 Sprag
[Re: justinp61]
#2330761
07/03/17 04:36 PM
07/03/17 04:36 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
The trans already has a billet steel front drum and I have a nearly new bolt in sprag. I was just curious as to when a better one was needed. When you decided to put in the current 12 bolt. Rarely does the outer race's press fail , its the 12 rollers that fail. Your current unit still can fail, it takes more to make a 16 roller fail.
Re: 727 Sprag
[Re: JohnRR]
#2330799
07/03/17 06:08 PM
07/03/17 06:08 PM
John_Kunkel
Rio Linda, CA
Yep, here's a 16-element SuperSprag failure with the cam ring in place.
Re: 727 Sprag
[Re: John_Kunkel]
#2331152
07/04/17 02:49 AM
07/04/17 02:49 AM
Posts: 4,695 Wichita
GY3
Wichita
Yep, here's a 16-element SuperSprag failure with the cam ring in place. What causes that? I have lots of miles, strip passes and even a few u-joints that broke. I always pull apart the trans to check the sprag after a failure and never had an issue. I do have a LBA forward pattern manual valvebody and always shift to second on the burnout.
Re: 727 Sprag
[Re: John_Kunkel]
#2332534
07/06/17 03:05 PM
07/06/17 03:05 PM
JohnRR
U.S.S.A.
Yep, here's a 16-element SuperSprag failure with the cam ring in place. Something seriously wrong happened there , downshift into low at about 100mph with no LBA ???
Re: 727 Sprag
[Re: JohnRR]
#2332828
07/06/17 11:49 PM
07/06/17 11:49 PM
Posts: 9,867 MI, usa
dvw
MI, usa
Yep, here's a 16-element SuperSprag failure with the cam ring in place. Something seriously wrong happened there , downshift into low at about 100mph with no LBA ??? Saw one just like it in a 10.0 foot brake car that broke a ring gear. Doug
Re: 727 Sprag
[Re: John_Kunkel]
#2333208
07/07/17 05:40 PM
07/07/17 05:40 PM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
That is my photo, its from my friends valiant. +900hp 1080nm big block. It broke the rear end (8 3/4) and after about 10passes it grenaded the sprag.
The case got a small crack but we didnt have spare one at the time, installed new super sprag and after around 25-35 passes it broke again. Picture attached.
It has aluminum drum and in both cases the springs were all over the place, retainer still in place. Drum had spinned very fast.
I fixed it again few weeks ago with new good case and new super sprag and few other items. Week ago it went 8.88s at 1/4 with zero problems so far, fingers crossed.
-1965 Valiant 9.03s 358cu.in R5P7-
