A-Body vs B-Body exhaust tips #2328016
06/28/17 12:10 PM
06/28/17 12:10 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I have a 69 barracuda that I am putting on dual exhaust. The car was originally a /6 so I have to buy exhaust tips, tip hangers, etc. My dad has a set of exhaust tips from his 69 roadrunner from back in the day. My questions are..
How much different are these tips compared to an A-Body tip? (Mounting tab, dimensions, etc)
Would they work on my cuda?
Will the stock a-body exhaust tip hanger work or a custom on need be made?
Re: A-Body vs B-Body exhaust tips [Re: DusterKid] #2328023
06/28/17 12:25 PM
06/28/17 12:25 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I know that the B body tip is shorter than the A body (at least mid 70's Abody) . . . the tab on the top for the hanger is the same, just would need to move the hanger to correct spot for the B body tip. Also, think the B body tip is different outlet shape (oval versus square for A body) . . . I am sure that if you get the B body tips and mock them up on your car, you can figure it all out . . .
Re: A-Body vs B-Body exhaust tips [Re: a12rag] #2328228
06/28/17 08:03 PM
06/28/17 08:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The 69 Barracuda tip is the shortest one that was made for the A-Body, so it may be the same length as the Road Runner, but definitely different end as mentioned above.
JB Rhinehart, Realist
A-Body's RULE!
Re: A-Body vs B-Body exhaust tips [Re: DusterKid] #2328394
06/29/17 01:11 AM
06/29/17 01:11 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A-body Barracudas had the rectangular tip like Dodges generally did, didn't they? (as opposed to the '68-'70 Plymouth B oval tips). Overall lengths differ as do the hanger tab locations.
