Painting Valve Covers - Primer? #2327194
06/26/17 10:33 PM
06/26/17 10:33 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Whenever I painted a set of valve covers, I never used a primer on them - just the engine paint and they have held up well.
Does anyone here use a primer? If so, what type?
Just curious.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Painting Valve Covers - Primer? [Re: Erik] #2327246
06/26/17 11:21 PM
06/26/17 11:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I always spray an engine's bare surface and any of it's components that are going to be painted in Dupont etch primer be it cast iron, steel, aluminum
Re: Painting Valve Covers - Primer? [Re: Erik] #2327284
06/27/17 12:09 AM
06/27/17 12:09 AM
BlueRacer69 Offline
BlueRacer69  Offline
Yes. I primed my valve covers with a high temp (500 degree) ceramic engine primer before painting them. I think the brand was Dupli-color in a spray can. That was about 5 yrs ago. Its held up well so far.
Re: Painting Valve Covers - Primer? [Re: Erik] #2327289
06/27/17 12:21 AM
06/27/17 12:21 AM
WA
tman Offline
tman  Offline
WA
I have never used primer and have had no issues so far at 10 yrs. No harm to use primer. To me, paint is insulation keeping heat in. Probably negligible.
Re: Painting Valve Covers - Primer? [Re: Erik] #2327460
06/27/17 11:47 AM
06/27/17 11:47 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
A thin coat of etching primer on the stamped steel covers is a good idea.
Master, again and still
Re: Painting Valve Covers - Primer? [Re: Erik] #2327494
06/27/17 01:06 PM
06/27/17 01:06 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Do any of you paint the insides of the cover?
Re: Painting Valve Covers - Primer? [Re: Erik] #2327506
06/27/17 01:40 PM
06/27/17 01:40 PM
BlueRacer69 Offline
BlueRacer69  Offline
No. Never. The oil splashing on the inside of them will coat them and keep them from rusting inside.
Re: Painting Valve Covers - Primer? [Re: BlueRacer69] #2327592
06/27/17 05:00 PM
06/27/17 05:00 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yeah, leave the insides raw steel. Paint can flake off as well.
Speaking of valve covers I once had a set of old chromed DC valve covers for a small block and I pulled the baffles out and found large loose pieces of chrome plating just barely hanging on where the baffles were at. Having those fall off and end up in the oiling system would not be great.
Re: Painting Valve Covers - Primer? [Re: Erik] #2327995
06/28/17 11:40 AM
06/28/17 11:40 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks for the replies. I am currently restoring a set and the insides look like they were painted with that rattle can undercoating or something. Never seen anything like it. Been a pain to scrape and blast off. Ugh.
Re: Painting Valve Covers - Primer? [Re: Erik] #2327998
06/28/17 11:45 AM
06/28/17 11:45 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Blasting valve covers is not a good idea !! work
Re: Painting Valve Covers - Primer? [Re: 62maxwgn] #2328032
06/28/17 12:39 PM
06/28/17 12:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
A little off topic but I'll fog a light coat of primer on an assembled engine before I paint it. Can't remember the exact number but it's a Krylon primer.
Re: Painting Valve Covers - Primer? [Re: 62maxwgn] #2328037
06/28/17 12:46 PM
06/28/17 12:46 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I blast them all the time. Never had a problem. Just make sure they are blown out really well before you paint them/use them.
