Painting Valve Covers - Primer?
#2327194
06/26/17 10:33 PM
06/26/17 10:33 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
Whenever I painted a set of valve covers, I never used a primer on them - just the engine paint and they have held up well.
Does anyone here use a primer? If so, what type?
Just curious.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Painting Valve Covers - Primer?
[Re: Erik]
#2327289
06/27/17 12:21 AM
06/27/17 12:21 AM
Posts: 566 WA
tman
WA
I have never used primer and have had no issues so far at 10 yrs. No harm to use primer. To me, paint is insulation keeping heat in. Probably negligible.
[Re: Erik]
#2327460
06/27/17 11:47 AM
06/27/17 11:47 AM
Posts: 11,994 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A thin coat of etching primer on the stamped steel covers is a good idea.
Master, again and still
[Re: Erik]
#2327494
06/27/17 01:06 PM
06/27/17 01:06 PM
Erik
Stroudsburg, PA
Do any of you paint the insides of the cover?
[Re: Erik]
#2327506
06/27/17 01:40 PM
06/27/17 01:40 PM
Posts: 727 Michigan
BlueRacer69
Do any of you paint the insides of the cover? No. Never. The oil splashing on the inside of them will coat them and keep them from rusting inside.
[Re: Erik]
#2327995
06/28/17 11:40 AM
06/28/17 11:40 AM
Erik
Stroudsburg, PA
Thanks for the replies. I am currently restoring a set and the insides look like they were painted with that rattle can undercoating or something. Never seen anything like it. Been a pain to scrape and blast off. Ugh.
[Re: 62maxwgn]
#2328032
06/28/17 12:39 PM
06/28/17 12:39 PM
Posts: 10,696 North Dakota
6PakBee
North Dakota
A little off topic but I'll fog a light coat of primer on an assembled engine before I paint it. Can't remember the exact number but it's a Krylon primer.
[Re: 62maxwgn]
#2328037
06/28/17 12:46 PM
06/28/17 12:46 PM
Erik
Stroudsburg, PA
Thanks for the replies. I am currently restoring a set and the insides look like they were painted with that rattle can undercoating or something. Never seen anything like it. Been a pain to scrape and blast off. Ugh. Blasting valve covers is not a good idea !! I blast them all the time. Never had a problem. Just make sure they are blown out really well before you paint them/use them.
