Holly Model 2300 Fuel filters #2327234
06/26/17 11:05 PM
06/26/17 11:05 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Day All
Been awhile since I've posted. Been working on a Tri-power '66 GTO.
Anyway, This is for the 6 pack/6BBL crowd:
Are there suppose to be filters in each carb? I have a 71 service manual that does not mention any. Mine did not have any so I added them (the sintered metal ones from Wix) along with the appropriate springs last winter. I finally got the '68 out today (first time this year) to fill it up. It started and idled great but is a total dog under full acceleration. The vacuum pods appear to be working but I cannot see any fuel in the outboard carbs when you blip the throttle. The center carb appears to be doing all the work.
Since the fuel lines are a pain to seal I thought it wise to ask first instead on tearing into it.
Thanks to all who respond.
Omni
Re: Holly Model 2300 Fuel filters [Re: Omni Source 1] #2327370
06/27/17 02:33 AM
06/27/17 02:33 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
First thing I would do is remove the sight plugs and see if there is gas in the bowls. Never had those filters cause an issue unless you have a really dirty fuel system.
Re: Holly Model 2300 Fuel filters [Re: Omni Source 1] #2327397
06/27/17 04:41 AM
06/27/17 04:41 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There were no filters originally
Re: Holly Model 2300 Fuel filters [Re: Omni Source 1] #2327405
06/27/17 08:00 AM
06/27/17 08:00 AM
Ohio in the USA
O
O
Ohio in the USA
Good Morning
Thanx Morty426.
I did remove the sight plugs with no fuel evident. That is why I asked about the filters.
Looks like I'll be removing the fuel lines.
Omni
Re: Holly Model 2300 Fuel filters [Re: Omni Source 1] #2327535
06/27/17 02:56 PM
06/27/17 02:56 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
No filters in mine and mine are aftermarket.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Holly Model 2300 Fuel filters [Re: Omni Source 1] #2328574
06/29/17 01:44 PM
06/29/17 01:44 PM
Chicago
PurpleBeeper Offline
Chicago
I've never run the filters inside the carbs, but good fuel filters before the carbs. I've thought about it several times since they are shown in the carb diagrams, but never wanted to limit my fuel flow.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
