L.A. built tail stripes #2325410
06/22/17 08:30 PM
06/22/17 08:30 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Did the L.A. plant apply the tail stripe on the reflector housings on the 69 Dodges like the other plants or were the reflector housings put on after the stripe was put on?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: L.A. built tail stripes [Re: 6T9Hemi] #2325512
06/23/17 12:12 AM
06/23/17 12:12 AM
BlueRacer69 Offline
BlueRacer69  Offline
popcorn
Re: L.A. built tail stripes [Re: 6T9Hemi] #2325516
06/23/17 12:16 AM
06/23/17 12:16 AM
BlueRacer69 Offline
BlueRacer69  Offline
I think reflector housings were painted. The tail strip was not part of it.
Re: L.A. built tail stripes [Re: BlueRacer69] #2325811
06/23/17 04:59 PM
06/23/17 04:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Well they were "supposed" to be painted and all of the other plants painted the reflector bezel the stripe color so we would need a survivor from the LA plant to confirm ALL of the assembly plants matched the reflector bezel to the stipe color. Over on the A12 Registry there are many Lynch Road examples of the reflector bezel matching the stripe color and how the tail stripe was cut and wrapped inside of the reflector quarter panel hole and into the trunk.
MikeR
Re: L.A. built tail stripes [Re: A12] #2325815
06/23/17 05:03 PM
06/23/17 05:03 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here a 5600 mile survivor '69 A12 from the LYNCH ROAD (not LA) Assembly plant: http://a12mopar.com/yabb/YaBB.pl?num=1197019589;start=all
(Also note the forward offset of the stripe over the reflector, it is NOT centered over the '69 Super Bee rear reflector as a lot of installers incorrectly center it. This one is more offset than most but all of the original Lynch Road stripes are offset forward.)
Re: L.A. built tail stripes [Re: A12] #2325821
06/23/17 05:25 PM
06/23/17 05:25 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
I believe the stripes were suppose to be centered, but back then, quality control lacked a bit.
Re: L.A. built tail stripes [Re: 6T9Hemi] #2325830
06/23/17 05:49 PM
06/23/17 05:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Disagree, if that was the case then QC missed about 99.9% of all of the original misaligned '69 Super Bee tail stripes. Example of some survivors and back in the day photos:
Survivor:
Re: L.A. built tail stripes [Re: A12] #2325834
06/23/17 05:53 PM
06/23/17 05:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Friend and co-worker's Super Bee back in 1969" :
I'll post more and more offset Super Bee tail stripes soon. Over on the A12 Registry we've been investigating this for decades now so there's plenty of ORIGINAL offset examples out there.
MikeR
Re: L.A. built tail stripes [Re: A12] #2325835
06/23/17 05:55 PM
06/23/17 05:55 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Good info!
Re: L.A. built tail stripes [Re: A12] #2325837
06/23/17 05:57 PM
06/23/17 05:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Quick one the low mile "Butter Bee" 's tail stripe offset:
Re: L.A. built tail stripes [Re: A12] #2325841
06/23/17 06:14 PM
06/23/17 06:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Factory studio photo scope
Re: L.A. built tail stripes [Re: A12] #2325847
06/23/17 06:29 PM
06/23/17 06:29 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Would love to see something from L.A.
Re: L.A. built tail stripes [Re: 6T9Hemi] #2325962
06/24/17 12:01 AM
06/24/17 12:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy owned a metallic tan LA built 69 340 swinger with what appeared to be original stripes and mostly original paint. Hood replaced with factory part. The swinger stripe I thought has the same outside dimensions as a GTS stripe???
Moparts member KSJ ? In Kansas owns it now.
Re: L.A. built tail stripes [Re: 6T9Hemi] #2325980
06/24/17 01:22 AM
06/24/17 01:22 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I found some pics of it.
69 340 swinger
LA plant
All numbers including build sheet (yes in an LA car!)
Re: L.A. built tail stripes [Re: autoxcuda] #2326211
06/24/17 08:35 PM
06/24/17 08:35 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Thanks for the pics. Driver's side looks like the reflector bezel is black and can't tell what's going on with the passenger side.
Re: L.A. built tail stripes [Re: A12] #2326950
06/26/17 01:50 PM
06/26/17 01:50 PM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
My 70 Bee from Lynch Road has the (OE)stripe installed like this on passenger side, but driver side is centered. Luckily you can't see both sides at the same time. ;-)
Re: L.A. built tail stripes [Re: SuperRob] #2327050
06/26/17 05:37 PM
06/26/17 05:37 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have seen the TSB on stripe replacement and they ARE supposed to be centered, but most weren't. My 69 GTS had a GT SPORT stripe on one side and a SWINGER stripe on the other from the factory, so what is this QC you are talking about? laugh2
JB Rhinehart, Realist
A-Body's RULE!
Re: L.A. built tail stripes [Re: Rhinodart] #2327427
06/27/17 10:30 AM
06/27/17 10:30 AM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Now that is special! smoke
