Re: Mickey Thompson Expands Pro Bracket Radial Line
[Re: pittsburghracer]
#2324937
06/21/17 09:59 PM
06/21/17 09:59 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i always hoped they would do a true 29" guess I will keep hoping .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: SILVER67]
#2325090
06/22/17 04:48 AM
06/22/17 04:48 AM
tex013
Sydney,Australia
Perhaps in time they'll do a 29"
The 9x28 PBR has been phenominal !!
A 9x29 or 9x29.5 would be heavan !! I have run the 28x10 for 18 months and wouldn't change back to any other radial - traction and life . Tried a 295/65R15 et street radial (30.5") - chewed the doglegs when off throttle through the traps . Scared the bejesus out of me first time . Otherwise need to space diff back a little Tex
[Re: SILVER67]
#2325193
06/22/17 01:04 PM
06/22/17 01:04 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I cant fit a 28x10 under a 66-67 b-body
Hoosier makes a 9 x 29.5 p/n = 18210
I think if I ever need a taller tire that would be next, unless M/T made the PBR in 29.5 or 30 Are you sure a 29.5" tall tire would fit with the axle in the stock location? On my car with 28" tires, the tire is real close to the front edge of the fenderwell at the sill (bottom of the body).
#2325298
06/22/17 04:18 PM
06/22/17 04:18 PM
fast68plymouth
So. Burlington, Vt.
Those are the "short" 30" version. 92.5" rollout. The tall ones are 94.0" rollout.
[Re: fast68plymouth]
#2325582
06/23/17 03:23 AM
06/23/17 03:23 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Those are the "short" 30" version. 92.5" rollout. The tall ones are 94.0" rollout. When I raced my "stocker" I would ask for the tallest 9x30x15 bias ply slicks the west coast Firestone warehouse had, I've had more than one set that had 95.5 + inch circumference ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) Luckily I never went fast enough to get protested or torn down in that car ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
#2325602
06/23/17 05:38 AM
06/23/17 05:38 AM
tex013
Sydney,Australia
Those are the "short" 30" version. 92.5" rollout. The tall ones are 94.0" rollout. spot on - 30x9 = 29.5", 9x30= 30" Tex
#2325617
06/23/17 08:57 AM
06/23/17 08:57 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I am running the 28x10.50 pro bracket and have been happy with them. My first pass on them was a new best 60ft and I wasn't having traction problems prior to that.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2325650
06/23/17 10:48 AM
06/23/17 10:48 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I am running the 28x10.50 pro bracket and have been happy with them. My first pass on them was a new best 60ft and I wasn't having traction problems prior to that. 10 or 12" wheel?
#2325666
06/23/17 11:15 AM
06/23/17 11:15 AM
Bad340fish
Tulsa OK
I am breaking the rules with an 8" rim haha.
