Mickey Thompson Expands Pro Bracket Radial Line #2324898
06/21/17 08:15 PM
06/21/17 08:15 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2324900
06/21/17 08:17 PM
06/21/17 08:17 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2324937
06/21/17 09:59 PM
06/21/17 09:59 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
i always hoped they would do a true 29"
guess I will keep hoping .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: tex013] #2325004
06/21/17 11:50 PM
06/21/17 11:50 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Perhaps in time they'll do a 29"
The 9x28 PBR has been phenominal !!
A 9x29 or 9x29.5 would be heavan !!
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: SILVER67] #2325090
06/22/17 04:48 AM
06/22/17 04:48 AM
Sydney,Australia
Sydney,Australia
I have run the 28x10 for 18 months and wouldn't change back to any other radial - traction and life .
Tried a 295/65R15 et street radial (30.5") - chewed the doglegs when off throttle through the traps . Scared the bejesus out of me first time . Otherwise need to space diff back a little
Tex
New best MPH 130.32
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: tex013] #2325134
06/22/17 10:35 AM
06/22/17 10:35 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I cant fit a 28x10 under a 66-67 b-body
Hoosier makes a 9 x 29.5 p/n = 18210
I think if I ever need a taller tire that would be next, unless M/T made the PBR in 29.5 or 30
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: SILVER67] #2325193
06/22/17 01:04 PM
06/22/17 01:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Are you sure a 29.5" tall tire would fit with the axle in the stock location? On my car with 28" tires, the tire is real close to the front edge of the fenderwell at the sill (bottom of the body).
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: StealthWedge67] #2325291
06/22/17 03:59 PM
06/22/17 03:59 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Little snug
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: SILVER67] #2325292
06/22/17 04:02 PM
06/22/17 04:02 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
smaller 9 x 30
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: SILVER67] #2325294
06/22/17 04:08 PM
06/22/17 04:08 PM
PA.
"Little"John
"Little"John
PA.
A sawzall will fix that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2325298
06/22/17 04:18 PM
06/22/17 04:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Those are the "short" 30" version.
92.5" rollout.
The tall ones are 94.0" rollout.
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2325532
06/23/17 12:52 AM
06/23/17 12:52 AM
Puyallup, WA
Puyallup, WA
That's interesting. Every car is a little different I suppose, but here's mine, it's a Plymouth, but I have less than 3/4" and these are 28x9's, which MT says measure 27-1/2".
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: fast68plymouth] #2325582
06/23/17 03:23 AM
06/23/17 03:23 AM
92.5" rollout.
When I raced my "stocker" I would ask for the tallest 9x30x15 bias ply slicks the west coast Firestone warehouse had, I've had more than one set that had 95.5 + inch circumference devil
Luckily I never went fast enough to get protested or torn down in that car whistling
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: fast68plymouth] #2325602
06/23/17 05:38 AM
06/23/17 05:38 AM
Sydney,Australia
Sydney,Australia
92.5" rollout.
spot on - 30x9 = 29.5", 9x30= 30"
Tex
New best MPH 130.32
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2325617
06/23/17 08:57 AM
06/23/17 08:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am running the 28x10.50 pro bracket and have been happy with them. My first pass on them was a new best 60ft and I wasn't having traction problems prior to that.
68 Barracuda Formula S 340
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: Bad340fish] #2325650
06/23/17 10:48 AM
06/23/17 10:48 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
10 or 12" wheel?
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2325666
06/23/17 11:15 AM
06/23/17 11:15 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am breaking the rules with an 8" rim haha.
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: pittsburghracer] #2325711
06/23/17 01:03 PM
06/23/17 01:03 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Every car is different for sure. I ran the old MT 29.5x9 on my car for years before we split the tubs and moved the springs. I was on old super stock springs back then. Maybe the caltrac spring has a shorter front spring segment or mounting point?
I run 29.5x10.5x15W now with room. Not much room...
Re: Mickey Thompson Expands Pro Bracket Radial Line [Re: StealthWedge67] #2325775
06/23/17 03:20 PM
06/23/17 03:20 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I think Dodge's are supposed to have a 1" longer wheelbase.
This is the 9x28 PBR
