Page 3 of 3 1 2 3
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #2325336
06/22/17 05:41 PM
06/22/17 05:41 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Drop the valve body and tap out the seal from underneath. Pull the new one in with a piece of threaded rod, two nuts, and two washers. Easy project and a good time to adjust the bands, while you're already soaked with ATF.
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #2325337
06/22/17 05:42 PM
06/22/17 05:42 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #2326266
06/25/17 12:19 AM
06/25/17 12:19 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
IIRC correctly there's TWO seals - one that seals the large shift lever shaft to the case, and a 2nd seal, an "o-ring" type of seal for lack of a better tem for it(and not a metal cased one) for the kd shaft that runs thru the center of the larger shaft that is sealed by the larger washer. I'd drop the valve body and change both, for piece of mind. The 2nd seal is under the e clip and washer.
Re: How to replace shift shaft seal on 727 trans? [Re: Sixpak] #2326532
06/25/17 06:14 PM
06/25/17 06:14 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The two seals.
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #2327049
06/26/17 05:37 PM
06/26/17 05:37 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I just use a small pick and get them out.
Nautilus Racing-
Page 3 of 3 1 2 3
