Rear end yoke, Dana 60, which style is stronger? #232512
02/22/09 12:42 PM
02/22/09 12:42 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
My Dana currently has a yoke w/ 2 bolts and a metal strap that retains the 1350 u-joint. A buddy gave me a Moser yoke that has 2 u-bolts....Any sig. difference between the 2 strength wise? Performance wise? Thanks
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Rear end yoke, Dana 60, which style is stronger? [Re: HemiRick] #232513
02/22/09 12:52 PM
02/22/09 12:52 PM
Canada
CrAzYMoPaRGuY Offline
Canada
The through U bolts are preferred I do believe...
CrAzYMoPaRGuY
Re: Rear end yoke, Dana 60, which style is stronger? [Re: HemiRick] #232514
02/22/09 12:52 PM
02/22/09 12:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not trying to sway you in either direction but you
have to look at a couple of things. The heaviest load
carrying rear end is a big dana in trucks.... what do
they use... the straps and bolts. Also look at the design
of a yoke... the U-joint cup sets in OVER 1/2 way so
the load is applied to the yoke.... not the strap.
I've been running a strap type for 11 years on my car
(same ones and the same bolts). The strap is there
for 1 thing only... thats to hold the drive shaft/
U-joint from sliding forward
Re: Rear end yoke, Dana 60, which style is stronger? [Re: MR_P_BODY] #232515
02/22/09 12:54 PM
02/22/09 12:54 PM
Canada
Canada
I've never had any issues with the straps......
CrAzYMoPaRGuY
Re: Rear end yoke, Dana 60, which style is stronger? [Re: CrAzYMoPaRGuY] #232516
02/22/09 01:08 PM
02/22/09 01:08 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Thanks sounds like I can do nothing and be ok. Maybe even sell the unneeded Moser one!
Re: Rear end yoke, Dana 60, which style is stronger? [Re: HemiRick] #232517
02/22/09 01:15 PM
02/22/09 01:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the one your buddy gave you is a billet yoke and
you have a cast yoke, I'd change it, the billet is
stronger than the cast... but thats the only reason
Re: Rear end yoke, Dana 60, which style is stronger? [Re: MR_P_BODY] #232518
02/22/09 01:41 PM
02/22/09 01:41 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
It's a PY500 which is listed on Mosers site as forged rather than cast...No mention of billet except for the alum ones. The one installed is what came on a Strange built axle.
