Big block oil pump ?????? #2324712
06/21/17 02:02 PM
06/21/17 02:02 PM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
Posted this a long time ago,nobody knew,still trying to figure it out.Bottom picture on right is stock pump.
Re: Big block oil pump ?????? [Re: 62maxwgn] #2324761
06/21/17 03:03 PM
06/21/17 03:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What's the question?
Don't be the exception.
Re: Big block oil pump ?????? [Re: 62maxwgn] #2324781
06/21/17 03:43 PM
06/21/17 03:43 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Looks like a high volume pump to me.
Re: Big block oil pump ?????? [Re: stumpy] #2324786
06/21/17 03:55 PM
06/21/17 03:55 PM
dogdays Offline
dogdays  Offline
There are interesting marks in the 7-9 o'clock areas on the second picture from top. If the impeller rotates clockwise in that picture, the marks are probably cavitation.
R.
Re: Big block oil pump ?????? [Re: 62maxwgn] #2324835
06/21/17 05:57 PM
06/21/17 05:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Stock pumps have the elongated hole put given the passage from the block is round its questionable as to the benefit. Smoothing the rough casting in all those ports is a definite bonus.
I imagine the slotted rotor is someone's idea for lubrication. How many millions of pumps are out there without the slot ?!?!? Pointless.
Re: Big block oil pump ?????? [Re: Stanton] #2324845
06/21/17 06:22 PM
06/21/17 06:22 PM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
If it someones idea and pointless,then Chrysler is the culprit,that is a N.O.S. pump in the original box unopened when I got it 30 yrs ago !!
Re: Big block oil pump ?????? [Re: 62maxwgn] #2324917
06/21/17 09:18 PM
06/21/17 09:18 PM
I think everything has a reason (good or bad!). it may have been a slot to secure it for machining somewhere down the line but if that is the case you'd sure think all of em would have it (or something similar).
Re: Big block oil pump ?????? [Re: 62maxwgn] #2324957
06/21/17 10:42 PM
06/21/17 10:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well they haven't made them like that since so obviously they saw no point in it either !!!
Re: Big block oil pump ?????? [Re: Stanton] #2325058
06/22/17 01:46 AM
06/22/17 01:46 AM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
Just won't quit will you,as far as since,maybe just because you have never seen one thats an assumption on your part and you know what that can mean !!
Also if you want to turn a simple question into a p#####g match,no better place than Moparts ! pity
Re: Big block oil pump ?????? [Re: 62maxwgn] #2325064
06/22/17 02:03 AM
06/22/17 02:03 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Still not sure what it is you wanted to know, since you didn't post a question that I could see.
Re: Big block oil pump ?????? [Re: elmor353] #2325067
06/22/17 02:13 AM
06/22/17 02:13 AM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
The question was the purpose of the slot in the outer rotor!
Re: Big block oil pump ?????? [Re: 62maxwgn] #2325079
06/22/17 03:34 AM
06/22/17 03:34 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
They are built like that to start arguments. See how good it worked!
Re: Big block oil pump ?????? [Re: NANKET] #2325123
06/22/17 09:15 AM
06/22/17 09:15 AM
Blair County,PA
62maxwgn Offline OP
62maxwgn  Offline OP
Blair County,PA
Amen to that !!!
Re: Big block oil pump ?????? [Re: 62maxwgn] #2325179
06/22/17 12:44 PM
06/22/17 12:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
haha
Re: Big block oil pump ?????? [Re: 62maxwgn] #2325180
06/22/17 12:45 PM
06/22/17 12:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bill all the Melling pumps I have gotten in the last decade plus have at oval hole
Re: Big block oil pump ?????? [Re: 62maxwgn] #2325182
06/22/17 12:46 PM
06/22/17 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bill troll
