Re: Advice on rear end swap, with Caltracs
[Re: Donny]
#2325018
06/22/17 12:15 AM
06/22/17 12:15 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I like to disconnect lines,cables,driveshaft,etc... Then the u-bolts and remove the shackles and roll the rear out. I like to use braided stainless lines and plumb the calipers to the body. That way if you need to remove the rear you don't need to open the brake system in the future. Cal-Tracs seem to work better with sliders VS shackles. If you have a heavy car and a hard hitting drivetrain go for the +1" mono leafs. My mono leafs started sagging and went flat after a few years. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Donny]
#2325199
06/22/17 01:14 PM
06/22/17 01:14 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
Is this for a street driven car? If so, you better buy a kidney belt.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
