Re: Big block oil pump ??????
[Re: Stanton]
#2324845
06/21/17 06:22 PM
06/21/17 06:22 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Stock pumps have the elongated hole put given the passage from the block is round its questionable as to the benefit. Smoothing the rough casting in all those ports is a definite bonus.
I imagine the slotted rotor is someone's idea for lubrication. How many millions of pumps are out there without the slot ?!?!? Pointless. If it someones idea and pointless,then Chrysler is the culprit,that is a N.O.S. pump in the original box unopened when I got it 30 yrs ago !!
[Re: 62maxwgn]
#2324917
06/21/17 09:18 PM
06/21/17 09:18 PM
RapidRobert
I think everything has a reason (good or bad!). it may have been a slot to secure it for machining somewhere down the line but if that is the case you'd sure think all of em would have it (or something similar).
[Re: 62maxwgn]
#2324957
06/21/17 10:42 PM
06/21/17 10:42 PM
Posts: 8,906 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If it someones idea and pointless,then Chrysler is the culprit,that is a N.O.S. pump in the original box unopened when I got it 30 yrs ago !! Well they haven't made them like that since so obviously they saw no point in it either !!!
[Re: Stanton]
#2325058
06/22/17 01:46 AM
06/22/17 01:46 AM
62maxwgn
Blair County,PA
If it someones idea and pointless,then Chrysler is the culprit,that is a N.O.S. pump in the original box unopened when I got it 30 yrs ago !! Well they haven't made them like that since so obviously they saw no point in it either !!! Just won't quit will you,as far as since,maybe just because you have never seen one thats an assumption on your part and you know what that can mean !! Also if you want to turn a simple question into a p#####g match,no better place than Moparts !
[Re: NANKET]
#2325123
06/22/17 09:15 AM
06/22/17 09:15 AM
62maxwgn
Blair County,PA
They are built like that to start arguments. See how good it worked! Amen to that !!!
[Re: 62maxwgn]
#2325179
06/22/17 12:44 PM
06/22/17 12:44 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
[Re: 62maxwgn]
#2325182
06/22/17 12:46 PM
06/22/17 12:46 PM
JohnRR
If it someones idea and pointless,then Chrysler is the culprit,that is a N.O.S. pump in the original box unopened when I got it 30 yrs ago !! Well they haven't made them like that since so obviously they saw no point in it either !!! Just won't quit will you,as far as since,maybe just because you have never seen one thats an assumption on your part and you know what that can mean !! Also if you want to turn a simple question into a p#####g match,no better place than Moparts ! Bill
